Quoted from undrdog:I’ve got the polishing motor from Eastwood. A spiral wheel that I’m using brown compound on and a loose wheel that I’m using white compound on.
I’m working on some legs. Evaporust, spiral wheel, loose wheel, then Mother's Mag. It’s prettier than it was, but no reflections.
Should I get a stiffer wheel & rougher compound to start the process with? Maybe just use rougher compound on the spiral wheel?
I could go back to hand work and start around 400 or 600 wet, but the point of getting the motor and wheels was to make things easier.
Would appreciate any suggestions.
The kind of scratches you are working with you need more aggressive stuff.
400 isn't rough enough for the scratches you were facing. You probably need 220. Obviously the lower grit you are using, the more careful you need to be in terms of using anything powered. You also didn't need to go above 2000 grit if you weren't already working towards a mirror finish.
White compound on loose wheels is like plastic polishing. You need a tighter wheel if you are working to remove grain, etc. Green compound on a spiral wheel is my 'goto' for normal pinball polishing. It should take off ball trails and leave a high gloss finish without any additional rework.
600 grit is my goto graining grit if I recall. 800-1200->++ if you are going for that polished finish. But unless I'm trying to go mirror, I generally just stop with the green compound. Now a days I just use red and green scotchbrite pads if working heavy issues, then follow-up on the buffing wheel for polish. Using sandpaper only if I know I have to remove material to hide the defect.
For most parts, I start with green, and if there is still grooves or scratches, start using sandpaper moving your way down until you can see the defect being evened out. Then work your way back up in grit. Then use either the buffer wheel, or you can get green compound dremel-like accessories that you can use directly on the piece.
On that door, I would be moving down in grit until I see the lines break up with my sanding.. then start working up towards 600. The green compound on a mold can REALLY do some heavy cutting on its own saving lots of sanding.
