(Topic ID: 190105)
Police Force Start Up Issues
By n1teowl
2 years ago
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by Andyzola87
#1 2 years ago
I have an issue with my Police Force that is more annoying than anything. When I start up the machine after being off for awhile, it often has issues. Maybe a third of the time it starts up normally. The rest of the time it does one of two things. The most common scenario is that the GI will come on, but no displays. There will also be a hissing noise coming of of the speakers. The other times it comes on with all the GI, all segments lit on displays, and the police car attempting to move. I've had it pull out the police car belt this way as it doesn't know where the car actually is. The reason I say this is only annoying is that if I turn it off and turn it back on, it almost always boots right up. l don't think I've ever had to turn it on more than twice and then it plays normally. Any ideas on how to fix this? I replaced the batteries, but that's all I've tried. Thanks!
#2 2 years ago
I've read that this might be related to the power on reset circuit. Anyone have experiencing fixing the issue by addressing the components of that circuit?
#3 2 years ago
I think you may have power supply issues more than main board issues. I bet your 5 volts is a tad low on start up. If your power supply has never had the caps replaced, start there and replace them all. They have had a hard life and are cheap to replace. I bet after that your game will run quiet and stable every time you turn it on.
And if the car trouble persists...reflow the solders on the relay board under the playfield by the car motor . They all seem to have bad solders.
Good luck.
#4 2 years ago
Can you post a picture of the MPU and the power supply?
#5 2 years ago
Hey guys, thanks for the replies. I've attached pics of both of those boards. Thanks for the advice on the caps, I'm sure that's never been done. I did have a squirrely acting car and reflowed the solder on the relay and now it works great.
#6 2 years ago
yup redo all the caps on the power supply as they are all original and install a remote battery box asap or NVram is even better.
Your game will love you for it.
#7 2 years ago
redo r1 and r4 on the PS as well with 1 or 2 watt flame proof 39k ohm resistors, much better than stock. If they start to go/or are gone your high voltage will suffer making the displays not display as bright or at all.
#8 2 years ago
Measure voltages before doing anything
#9 2 years ago
just bought game about in may of this year, I love this game, only I have recently had problems, jet bumpers are going off with out the ball hitting them, also 2 balls come up at start of game and again during game play, police car also takes off when it should'nt. I am new to pinball. but i have replaced rubbers thru out the game and waxed up board with carnuva wax. But have not touched anything I am not sure about. If anybody out their knows what it might be, please let me know, thank you!
#10 2 years ago
Quoted from buffalobob:
#11 2 years ago
Quoted from n1teowl:
I think this is where you should focus your attention. I just fixed this same issue on my PF this week. I had the same symptoms as you: Game not booting regularly, scratchy loud speaker on startup, GI on but no displays. I replaced all my caps and resistors on my power supply (needed to be done anyways) and that did not fix the problem. I removed my CPU from the machine and bench tested it and it was still having the inconstant boot issue, so I knew my problem was on the CPU itself. Your problem is most likely cap C30 Which is part of the POR circuit. I pulled and replaced that cap with a 22uf 50 volt cap I had on hand and it fixed my problem. The cap I pulled from the game was out of spec reading 16uf which was not allowing the game to boot consistanly. I would start by replacing that one cap. It's easy to replace and most likely your issue IMO. However replacing all your Power supply caps is also a good idea.
$ 54.99
Hardware
Tucson Pinball
Gweem's Mods
$ 50.00
PinWoofer
$ 54.99
Metal-Mods
$ 18.99
2,195
New Kensington, PA
