Hi people.
I have a Police Force (Williams System 11B) with several problems.
----> The first one and more visible is the displays. The top line is always lit / on.
Probing around I found that touching with my logic probe in one UDN7180A pins the entire line / segments went off.
But during the process I damaged one UDN7180A and now I have two bad UDN7180A if I'm not mistaken.
To test the UDN7180A I have used this method:
Put the DMM on the *diode* setting.
Connect the red DMM lead to ground.
Put the black DMM lead on each UDN pin 2 to pin 8.
A reading of .5 to .7 should be seen.
Put the black DMM lead on each UDN pin 11 to 17.
a NULL (no) reading should be seen!
So now I have to search / buy some sockets and some UDN7180A chips to replace these.
----> The second problem is the sound, the music to be more precise. The machine have no music but have some sounds.
The 4 beep sound´s in the boot indicated a U19 problem If I´m not mistaken. So I have tested the rom´s and only the U21 was slightly different to the one in IPDB.
Erased and reprogrammed the U21 and now all roms are equal at the ones in IPDB.
This not solved the sound problem.
After some research I decided to swap the audio driver board with one from a Cyclone to verify if the problem are CPU board related or audio driver board related. With the Cyclone audio driver board (with the Police Force rom´s) all the sounds and music seems to work, so the problem are only in the audio driver board.
After some testing and probing to encounter the problem the Cyclone audio driver board stop playing music to. This was made with the board out of the machine and powered with a computer PSU.
To add a extra problem, now in the Police Force (not in Cyclone machine) I have a "tik tik" noise in speakers.
This "tik tik" after some time gets louder and after a little its stop. Probing U23 (YM2151) I have pulse at the rhythm of the "tik tik", and when the sound stop the pulse stop to.
With this kind of problem I assumed there is something wrong with the crystal or the oscillator. I swap the oscillator with one laying around (not sure if its okay) and nothing changed. Buy some new crystal´s and after changed it nothing as changed to.
I decided to make some measurements and probing to compare with a Earthshaker audio driver board (similar) to see if I can find the problem.
The 1 means High, the 0 means Low, the P means Pulse, and the 10P or the 01P means that I have a 1 and 0 and a Pulse in my probe. The X means I have nothing.
The components are the ones who make part of the crystal circuit. The R1 do not make part but I have a pulse in it when the "tik tik" sound exist so I decided to include it.
All the readings have been taken with a DMM and a Chinese component tester (probably not very accurate or trustworthy) in circuit in their appropriate machine.
I have just purchased a Chinese capacitance meter (M6013) and a ESR meter (MESR-100 V2) to help in the future with the capacitor, and a Portuguese ESR meter (EVB SBR) but right now I have to work with the tools I have.
So if someone can give me a little I really appreciated.
----> I have a third problem that I´ll address after repairing the audio drivers board and after receiving a ESR meter. The machine sometimes reset after activating something and other times plays fine.
Sometimes launching the ball and hitting the "spinning target" in the shooting lane it is enough to cause a reset.
The voltages in power supply board are good (when I verified them a time ago) but I do not have make any more research on this for now.
Thanks in advance.
