(Topic ID: 250372)
Police force flipper help needed
By buffaloatx
#1 4 years ago
Hey guys, I recently picked up a PF, overall it's in good shape, but recently the flippers have started dying for no apparent reason.
I've checked the voltages to the coils when they are working, flippers read around 65 volts(not under load) When they die I'm not getting any voltage at the coils. I've tested all the fuses on the aux driver board (all of them tested good out of circuit) and re-flowed the solder on all of the fuse housings with no results. All of the IDC connectors are unburnt and the male pins look untarnished.
If I leave the game off for a day or two every thing seems fine for about a day or so before the flippers die again.
Any ideas?
#2 4 years ago
No voltage at the coils what about voltage farther back in the circuit? You need to trace it back as far as you can go to find the dying components. The flipper circuit is pretty straigtforward - transformer to bridge rectifier/fuses, relay, then the interconnect board. It's probably going to end up being a cracked header on one of those boards.
#3 4 years ago
Thanks slochar, I failed to notice that the flippers went through the interconnect board. I'll do some digging and report back.
#4 4 years ago
Sorry for the delay, the real job has kept me too busy to work on this.
So there were a few suspect solder joints I found on the interconnect board, but they were mainly on the switch rows and GI headers, but since I had the board out of the game I re flowed every header and fuse holder and put the board back in the game. So far both flippers are working and seem a bit stronger than before.
I'm going to wait until after our Jurassic Park Launch event this weekend to mark this one solved, if it can take the abuse of a 3 hour match play tournament, then I'll be fairly certain it's fixed.
#5 4 years ago
Final update, re flowing solder on both the aux power supply and interconnect boards seems to have done the trick. The game did not die during our matchplay tournament this past weekend.
Marking as solved.
Thanks guys!
$ 36.95
$ 18.95
$ 27.00
Hardware
Tucson Pinball
$ 39.99
$ 22.50
$ 12.50
RoyGBev Pinball
$ 54.99
$ 95.00
Pinball Mod Co.
$ 19.99
This page was printed from https://pinside.com/pinball/forum/topic/police-force-flipper-help-needed and we tried optimising it for printing. Some page elements may have been deliberately hidden.
