Quoted from Crash:Where did you find a replacement jail plastic?
Seller gave me an extra when I got my game from him.
Quoted from galaga50:Anyone know where to get the decal for the firing range spinner?
Or is it a DIY jobbie
Ok so in my topper there was a mixture of 906 and 555 globes.
Is this right? I would have thought they're all the bigger ones.
Thoughts? Replace with all bigger flashers?
Quoted from Crash:That's correct. The 555 lamps are GI and the flashers are 906 sockets. The boards are designed that way.
Quoted from Netsepp:Hello,
i have to restore my entire playfield.
maybe someone has good scans of the playfield ?
thx Mike
If you are willing to wait i am sure that Peter from Buthamburg is planning on making them.
thank you,
I know him and have already ordered from him, but I'm already working on the playfield...
When the ball goes through the firing range spinner, is there meant to be any sounds? And like on Taxi, does the target amount change as the target spins?
I am trying to work out if my opto is broken or not.
Quoted from galaga50:is there meant to be any sounds?
Yes.
Quoted from galaga50:does the target amount change as the target spins?
Yes.
Well I finally found a speaker cover for the topper of my Police Force after almost 3 years.
See post #401.
1. Reinforced the inside of the cover with fiberglass, very thin plastic!
2. Mounted 5 inch speaker on pipe straps
3. Mounted the speaker to the cabinet top
4. Secured speaker cover with soft washers
Sounds Great!
IMG_8565 (resized).JPGIMG_8571 (resized).JPGIMG_8572 (resized).JPGIMG_8574 (resized).JPGHello! I bought my first pin about a month ago, a project condition Police Force. It needs a lot of work, and I'm doing a lot of reading, research, and starting to order some parts.
It's looking like I'll need to make my own spinner. Doesn't anyone have exact measurements for the spinner and shaft assembly? It looks like the spinner body is made of 3 metal sheets, one thicker in the middle, with space for the shaft. Does anyone have these measurements available, or willing to measure them for me?
I haven't made any progress yet, but you can follow my restore here:
https://pinside.com/pinball/forum/topic/warehouse-project-police-force-573-request-backup
Quoted from TwinCity:Hello! I bought my first pin about a month ago, a project condition Police Force. It needs a lot of work, and I'm doing a lot of reading, research, and starting to order some parts.
I have another run of printed spinners finished. I have to trim them a little bit will have them posted soon I hope.
Quoted from desertT1:I have another run of printed spinners finished. I have to trim them a little bit will have them posted soon I hope.
Great to hear!
I just picked up a Police Force, missing the topper. Anyone tried 3d printing replacement toppers for them?
New to the club, I have a Police Force missing the topper, anyone have one? PM me if you are willing to part with one and willing to ship if not near me.
Thank you
Can anyone take a picture of the light board behind the jail, mine is just laying down held up by the ramp and the wires, and am looking for a better idea of how it is supposed to be.
Just replaced all my plastics and rubbers, and now my pf doesn't recognize when the ball drains.
Not sure what has happened, anyone have any ideas?
So my machine sat in a garage for 12 years. So far I have fixed 3 switch errors, put new molexes on the interconnect board, GI as usual was burnt. I have replaced the rusted up legs, soldered on about 2 loose wires on the coin door, started to replace the bulbs with LEDs, I found the blue beacons for the topper and the light boards that go underneath, and have got the car running, it apparently had been broken long before it went to the garage for storage. I also got the flippers working, a fuse plus a loose wire. The list is far from done, but at least I am making progress on bringing this one back.
I also have the C and E on the lamp board not lighting underneath the playfield, might pull the board when I get a chance. And I have the famous diverter error, seems to be a regular thing, one of these days i will pull the playfield and get it fixed.
20210411_082916 (resized).jpgWell I replaced the diagnostics switch in my machine. Finally I can get through test mode, the old switch i had to mash repeatedly to get through one step.
Also, feel free to make fun of my soldering, I just started soldering with this machine, I described this job akin to a 12 year old boy giving it a go.
20210327_173226 (resized).jpg20210417_073613 (resized).jpg20210417_073712 (resized).jpg20210417_073816 (resized).jpgEveryone must start somewhere, I would say you need to do the green wire over as it will pop off soon. Buy some paste flux and apply the heat to the switch lead first. Soldering requires 3 hands to do it correctly, or you can insert the wire into the hole and bend it over and use 2 hands. YMMV. Any way keep practicing!
Playball!
Quoted from Froytheorc:Also, feel free to make fun of my soldering
Quoted from GRUMPY:Everyone must start somewhere, I would say you need to do the green wire over as it will pop off soon. Buy some paste flux and apply the heat to the switch lead first. Soldering requires 3 hands to do it correctly, or you can insert the wire into the hole and bend it over and use 2 hands. YMMV. Any way keep practicing!
Playball![quoted image]
Thank you! I will certainly redo it, I appreciate the advice.
Hey fellow police force owners. I've got a problem with a couple of the wire gates on my Police Force (1989) table. The two key problem spots are the middle ramp entry gate (that causes the drum-roll to invoke) and the other is the metal gate at the top of the playfield where you shoot the right orbit and wrap around to the G.U.N./TOP COP area. I've included clarifying images of each.
Quite frequently (at a guess maybe 25% of the time overall, maybe more) a ball that is hit very cleanly into the middle ramp will get stopped dead by the metal gate. When I test it with my finger I'm unable to reproduce it, so I'm not sure what exactly is malfunctioning. It seems that the gate must be getting bound on something, maybe the ball is hitting it high or something? And instead of swinging open it just punts the ball back. The metal gate up near the top of the playfield is a similar problem but it much more pervasive. I'd say that well over half the balls that get sent up the right orbit wall get rejected by the gate. Again, it moves when probed with the finger so I'm having a hard time understanding what is happening under play conditions that makes it deny entry.
I have tried the obvious of lubricating the gate hinges with some machine oil, but it hasn't fixed the problem. Perhaps the metal gets need a slight adjustment in their shape or something, but I don't want to mess with that before I see if someone else has been through this trouble shooting process and has a hot tip on what's likely needed.
1292a71204601395a8738bb7fd1559558fb5e7be (resized).pngffd35c553bab4de2ff0edf71eba96d04fb95d783 (resized).pngI have the same issue with the top gate. Did you check to ensure your entry onto the playfield gate isnt getting in the way of a shot? I feel like my shots hit there and get off trajectory just enough to stop it from clearing the top gate. I wonder if the hard black rubber near the gate is part of the issue (I have the same one there)
I have no issues with my ramp gate. Maybe take the gate out completely and verify your ramp entrance is not launching the ball into the Unlimited Millions bracket? Or add a couple spacers under the screws holding it in place?
Quoted from boscokid:I have the same issue with the top gate. Did you check to ensure your entry onto the playfield gate isnt getting in the way of a shot? I feel like my shots hit there and get off trajectory just enough to stop it from clearing the top gate. I wonder if the hard black rubber near the gate is part of the issue (I have the same one there)
Actually, I do occasionally have my shot snag the far side of the playfield entrance. There is very noticeable wear on the metal barrier there where the ball is catching it. When this occurs, though, it's very obvious and the ball doesn't make it to the gate at all. Anyway it sounds like this is a fairly common problem, so I'm going to probably ignore that issue while I focus on other fixes and then eventually look at what options might exist for changing the gate out for another style, like the wire one after the plunger shot.
As for the middle ramp, I did try backing out the screws holding the ramp down to take some of the angle off the metal ramp extension, but I think that this metal piece is somewhat bent already. I think what I'll try here is remove the ramp enough to remove the metal extension and flip it over and then also add washers to the ramp base like you suggested.
Another question for you Police Force owners. My volume potentiometer on the inside of the cabinet is jammed. It only has about 1mm of travel in it and goes from no volume to max volume with pretty much no gradient. I need to replace it. According to the documentation the machine calls for a 10K ohm pot here. I have a "b10k" pot on hand, but not sure that it's entirely compatible. It is also smaller than the one in the machine, with a shaft too small to attach to the bracket. I'd like to get a proper replacement for this pot, but it's so old that the text on the underside can't be fully read. I also understand there are different types of pots, some designed for volume, etc, and the owners manual doesn't talk about whether these differences matter or not.
Can anyone advise me on the terminology I need to use to find the correct part for this machine? Or is my smaller-shaft B10K pot sufficient for the task if I can just mount it somehow?
Pretty sure any 10k pot will work. I would remove the current one and see if it can be cleaned with isopropyl or deoxit first.
Here is something that shows the schematic from a sys11. I have this mod on my Jokerz! but not on my Police Force and honestly really never notice a difference.
https://pinside.com/pinball/forum/topic/system-11-volume-pot-value-game-too-loud
Quoted from boscokid:Pretty sure any 10k pot will work. I would remove the current one and see if it can be cleaned with isopropyl or deoxit first.
Great advice. I took apart the pot and rebuilt it and it's running fine again. There was a broken plastic tab inside that had caused it to jam up between the stops. It's wired up and working now but holy god the machine is just loud. The lowest volume is still louder than I would like I'm going to have to try the resistor bypass next and see how that goes.
Quoted from Blackbeard:Da Jews are MINE!!
Can't wit to hear these callouts again. I remember Police Force having some of the most sound effects of any System 11 machine. I may be remembering wrong, but we'll see. Should fit nicely between Bad Cats and Big Guns.
Chris
Has anyone purchased the mirrored Police Force backglass from CPR?
My translite is fine, just wondering if the "upgrade" is worth it.
Chris
Got the Police Force set up in the basement. Have some things I need to sort out, but it's up an running.
The flippers will need a rebuild, that's no big deal. I am getting a DIVERTER IN error and the ramp diverter doesn't seem to be functioning during gameplay or coil test. I'll dig into that, but am excited to get this one cleaned up!
Chris
Quoted from SilverUnicorn:Got the Police Force set up in the basement. Have some things I need to sort out, but it's up an running.
Chris
Ramp diverter is a very common problem with this machine. Unfortunately you must remove the entire playfield from the machine to access it. When I got my police force almost 2 years ago it would click a lot like it was trying to divert but nothing was happening. Took it apart. Cleaned it up and reinstalled. Been working perfectly since. Apparently it’s just one of those things
Quoted from Meri-cah:Ramp diverter is a very common problem with this machine. Unfortunately you must remove the entire playfield from the machine to access it. When I got my police force almost 2 years ago it would click a lot like it was trying to divert but nothing was happening. Took it apart. Cleaned it up and reinstalled. Been working perfectly since. Apparently it’s just one of those things
Thanks. It doesn't seem to do anything now. Bought the machine unshopped, so I expected some things to need to be done. Will address during the shop out. Thank you for the info!
I got a new cable for the police car too. Any ides on how to attach that? It is one long piece of plastic belt, but no way to attach the ends together
https://www.marcospecialties.com/pinball-parts/23-573-B
Chris
Subscribing as I should be joining the force by the end of January. It’s being shopped, so nothing should be broken on the playfield when I get it.
Did Soren ever do a ROM for this game?
OKay, so does anyone have detailed tear down pics of a police force shop out?
I took lots of photos (or so I thought) but an seriously stumped at some stuff and the order in which I removed it.
Chris
Quoted from SilverUnicorn:OKay, so does anyone have detailed tear down pics of a police force shop out?
Chris
Chris...I restored a Police Force once and have many detailed pictures.
PM me
Would anyone want my used ramps? They aren't totally trashed, but do have some damage (see pics).
The screw holes are also blown out to they would need larger screws at the entrance to keep them down.
Ramps are free but shipping would be pricey as the box would be large. If you are in the Allentown, PA area we could meet up for local pickup as well.
Chris
IMG_5603 (resized).jpgIMG_5604 (resized).jpgIMG_5605 (resized).jpgIMG_5606 (resized).jpgIMG_5607 (resized).jpgIMG_5608 (resized).jpgIMG_5609 (resized).jpgIMG_5610 (resized).jpgIMG_5611 (resized).jpgWanna join the discussion? Please sign in to reply to this topic.
This page was printed from https://pinside.com/pinball/forum/topic/police-force-club-we-enforce-the-law-of-the-jungle/page/10 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
