The backbox lights that are connect to J6-6 --F1--J7-8 are not working for some reason. DC volts is reading .05 volts or less. Based on the drawing it looks like power is supplied directly from the transformer and I should just be able to test for 5.9vac off the yellow whites off the transformer plug? If I am not getting 5.9vac off the yellow/whites then its a transformer issue? I tested continuity from yellow whites to the transformer from the lights and that is good. Or is this some problem with the interconnect board?
Thanks for any assistance!
