I had a issue with point score adjustment and it turned out that the 1,000 and 10,000 score reel wiper was misaligned and sending incorrect score to adjustment! The reel has an raised area where the wiper is suppose to be aligned, so be careful went reassembling if you took one apart! You can Validate with DMM on the Wiper PCB and the active wire on the PCB of the score reel should march the score indicates .. this is only relevant to the 1,000 and 10,000 reels.
