(Topic ID: 312124)
PMD Game Room Remodel
By PinballMikeD
1 year ago
    #1 1 year ago
    I always enjoy seeing home renovation projects, so thought I’d document and share my game room remodel here on PinSide. Hope you guys enjoy.
    Starting with the ceiling, working on my design for decorative beams. The concept is workable, just need to tweak the design at bit.
    851D4803-19AC-443E-A649-86FB6481D5CE (resized).jpegF2C637DA-6FBF-4CB6-A39E-F67217528264 (resized).jpeg
    #2 1 year ago
    Made some color swatches, leaning towards the darker “espresso” color.
    #3 1 year ago
    Main beam under way. Going with poplar wood for the exterior.
    3A137211-510E-4F39-8077-D9BCE6DCC4A6 (resized).jpegFFD560CE-9415-4638-8E54-BCFB19E936DD (resized).jpeg
    #4 12 months ago
    2 coats of stain and ready to go. I frictioned fitted the beam in place and secured it with drywall screws. Now it’s time to start laying out the nailers for the side beams.
    1815D2C8-9DCB-4C03-83EE-1BFE450A2AC7 (resized).jpeg2CACD862-E85C-43D8-8300-3A1FD9A9A950 (resized).jpeg
    Had to bring this in through the upstairs window. Fun fun.
    #5 11 months ago
    I got my 2x6s in place for the side beams. Now I need to put nailers up for the tongue and grove that will go in between the beams.
    DB4C92F7-6ED8-49E7-8736-9BD5B9A43663 (resized).jpegF7453688-FF58-4C3C-9D1C-76425DC91690 (resized).jpeg
    #6 11 months ago
    Whitewashing the tongue and groove that will get installed between the beams.
    17938E4E-E1A4-4B30-B78C-54A5FCD27B26 (resized).jpegC476B3F7-5DE0-4C9D-98A9-3BE1477004B8 (resized).jpeg
    3 weeks later
    #7 10 months ago
    Been hectic with work, but finally got my nailers up for the tongue and groove.
    BE51924E-08B0-4F09-8FCC-D842CBFEFB5C (resized).jpegCBEFFB55-DEDC-4199-95EF-F4F76BD1ADDF (resized).jpeg
    Now I need to rework the AC ducts.
    #8 10 months ago
    The changes to your room look very nice, but quite honestly I'm jealous of your shop area! Looks like you have a lot of nice power tools (Festool...), nice organization of your hand tools, and it is clear that the dust collection is working well!
    #9 10 months ago
    Thanks for the kind words. I wouldn’t attempt this project without the tools. I cleaned the shop before I started this project, so it’s not usually that clean
    #10 10 months ago
    I can tell from the precision of this first project the total remodel is going to be awesome! Following.
    #11 10 months ago
    The best part of a major remodel is all the new tools.
    #12 10 months ago
    If there's one thing I've learned from PMD threads, it's that you don't half ass anything lol. Looks amazing.
    #13 10 months ago
    Moved the AC supply and return into the wall.
    Upsized the Supply duct as my game room is on the west side of the house, hoping this will keep the room cooler.
    #14 10 months ago
    Picked up some cool dimmable LED lights for the ceiling. These should snap right into the tongue and groove, just need to route out the holes.
    Going to run the wire through all the beams.
    1E407B72-C82E-4820-B503-0F487A6A657E (resized).jpeg5ADC0E40-24A3-42F6-BA52-0EE71C58650E (resized).jpeg
    4 weeks later
    #15 9 months ago
    It’s been a few weeks, but finally got the ceiling up. I installed 12 LED lights, 6 on each side of the room (one circuit per group of 6).
    Now it’s time to build the side beams
    2158E9C9-E42E-4EFF-B183-8F75CE8CEC90 (resized).jpeg63B49E63-B176-44CE-A300-FA46DF09F589 (resized).jpeg
    #16 9 months ago
    Side beams complete.
    1C6A666C-29BB-4C78-913B-1565B359A2FF (resized).jpeg6CB1F19E-8835-4BDE-AE13-E040D9641A6A (resized).jpeg
    #17 9 months ago
    Time to run a designated 20Amp circuit for all the future pins. Because there is no attic space above the ceiling, I’m running the wire through the walls. Should be fun.
    9004C258-CD23-48A3-A008-022571AD3841 (resized).jpegD6D59BA8-3E11-4B26-BF7B-32A5FD50F163 (resized).jpeg
    #18 9 months ago
    The builder left me a present and I get to fix a leaking window
    #19 9 months ago
    My buddy had to add a mini-split to his upstairs gameroom FYI, the heat from all the games plus being a hot room in the Summer forced it. Hopefully the re-work on the ducts takes care of that.
    On a side note, are you putting in a cargo lift / elevator / device to help get games up and down?
    #20 9 months ago
    No cargo elevator. My room is right above the master bedroom, pretty sure the wife wants to keep it unaltered
    I have an escalera, so it isn’t too bad.
    I’m worried about the heat as well. I upsized the duct run to the room and it is feed directly from the plenum box, which is only 10ft from the diffuser. That seems to have helped, but we will see in July/August. I have a lot of acoustic guitars that will be stored in the room, so temp and humidity are a concern.
    #21 9 months ago
    Installing new outlets and replacing insulation.
    032A2DBB-8ECF-4D29-8CE9-32F2CEACFE3F (resized).jpegE9EF5AC1-4308-4687-9E8A-B56DC2B62A87 (resized).jpegFE6AC2FF-0139-496C-97F7-7AC293F90DD8 (resized).jpeg
    Because I have OCD, I’m adding some studs. This way I can line up all me outlets on parallel walls.
    #22 9 months ago
    Quoted from PinballMikeD:
    Me too, I once moved a structural beam holding up the second floor so a layout was perfectly aligned at a 45 degree angle. That is why my projects take a loong time.... Your project is looking real good!
    #23 9 months ago
    Man I hate drywall work. It’s an art that eludes me. I’ll get it done, but only after I sand 75% off of what I put on
    4314F3FD-E403-4E4A-B0E2-C280E1A42E9B (resized).jpeg4CF9DE4C-2F07-4C6F-BAD9-961805327930 (resized).jpegCEBEFA35-35BE-4F5C-BE60-B7A3BDCFF770 (resized).jpeg
    Tape and first coat of mud done.
    #24 9 months ago
    Quoted from ReadyPO:
    #25 9 months ago
    Looks like you are possibly using WAY too much. Unless your walls are crazy out of plumb, you should be able to get away with just single initial coat to just smooth over the tape joints, then maybe do a second coat if things are still popping through, then skim coat and done. The way you’ve gone over the entire wall there - you can save yourself a lot of time! Seems counterintuitive to do multiple coats and wait for them to dry but it’s way faster (and less messy) than sanding for a week.
    Waiting for it to dry is frustrating but you can use the 1 hour set (comes as a powder) and be done in a day. Mudding still sucks anyway you slice it though! Room is looking quite good
    #26 9 months ago
    2nd coat on and sanded.
    As bad as my mud work is, Festool can save it
    #27 9 months ago
    I had a friend come over and help me install the side beams. They are friction fitted over the nailers. I then used 6” long 1/4” screws to pull them up into place. No brad holes to touch up
    03171536-5DEC-4368-8BCB-D5F207231C9B (resized).jpeg0C31D431-A1D7-4761-A3B9-66B71BCA5384 (resized).jpeg
    No gaps, very happy with how these turned off.
    #28 9 months ago
    NICE work! Those look great. Is that real
    Wood for the ceiling planking, or the newer vinyl type?
    #29 9 months ago
    Looks great. Nice job!
    #30 9 months ago
    Quoted from Rdoyle1978:
    It’s pine tongue and groove. I sanded it to 320 and white washed it.
    #31 9 months ago
    Nice stain job for poplar.
    I hate these threads because now I want to start a project.
    #32 9 months ago
    Yeah poplar is a b$&ch. Minwax pre-conditioner is the only way to go. The dark stain makes it easier as well.
    Financed this project with the sale of Dead Pool. Nothing is free right
    #33 9 months ago
    Thinking of doing an accent wall. Picked up some sheets of MDF with a brick pattern from HD to play around with.
    Whitewashed
    CA940C75-6865-4126-98C0-C23B42A56143 (resized).jpegF41D45AD-AFFE-4D47-934F-5C84F9ECBDEE (resized).jpeg
    Added some color (same color I’m using for the walls), to give it some pop.
    Thoughts?
    #34 9 months ago
    Here’s a side by side comparison with the stock panel.
    #35 9 months ago
    I like the whitewash - I went a couple of steps further in my office:
    1. I cut the sheets out on the edge to zipper butting pieces together, and filled with a grey caulk;
    2. I did what is called a German Schmear using joint compound across the bricks. Sealed with a polyurethane.
    #36 9 months ago
    I was planning on zippers as well. I like the idea of the joint compound. Did you water it down any?
    #37 9 months ago
    Didn't water it down, just made sure to vary the thickness so bricks show through. When you put the Polly on (water based) it will thin it out and more of the red will show.
    #38 9 months ago
    Ok, I might color all my bricks brown as I’m looking to get away from the red. Thanks for the input.
    #39 8 months ago
    First skim coat up.
    Eliminating some unused electrical outlets.
    #40 8 months ago
    Patching repairs complete and skim coated wall. I’m getting better at drywall work, but not quitting my day job anytime soon
    #41 8 months ago
    I decided to color all the whitewashed bricks. Here’s the first panel. Another day of brick painting and I’ll be ready to start installing them.
    3FDCC228-707F-455A-91B5-AD879E31989B (resized).jpeg9D695F69-8C69-4810-B516-CD5D17FC75DB (resized).jpeg
    #42 8 months ago
    Cutting my zippers.
    So far so good
    385864A1-B275-42BD-9AF7-74337BBAABAE (resized).jpeg8A1F152D-ACE2-4A68-9E55-2390BAEF2250 (resized).jpeg
    3 months later
    #43 4 months ago
    Nice job with the brick!
    #44 4 months ago
    Quoted from PAPPYBALL:
    Thanks, it’s been slow going as of late. Work has been crazy, but I did manage to get most of the paneling and sparkle up.
    #45 4 months ago
    Thanks to ReadyPO for the German Schmear idea. That made filling the zipper seams much easier and added some character. Here’s a close up pic.
    This page was printed from https://pinside.com/pinball/forum/topic/pmd-game-room-remodel and we tried optimising it for printing. Some page elements may have been deliberately hidden.
