(Topic ID: 209160)
Plunge Router splintering plywood
By SealClubber
6 years ago
    #1 6 years ago
    I was cutting a new lamp display panel using a plunge router. The display holes are fine. For the lamp holes, I used a 1/2" straight bit with my plunge router. No matter how lightly I pressed, it did not cleanly cut the final ply and pushed through and splintered the back side so I have a lot of holes with large gashes around them. Not a great big deal for this panel as it is the back side, behind a backglass so nobody will see it unless during maintenance. However, I would like to prevent this for any future builds. For you woodworker experts here, what is the best way to do this right and make a nice clean hole all the way through?
    #2 6 years ago
    Clamp a second piece of wood under the area you are drilling. When you drill through the first piece of wood and into the second, there should be no splintering then.
    #3 6 years ago
    Did you pre-drill the panel or rely on the router to do that? I always pre-drill to minimize tearout.
    Like FF mentioned, clamp a scrap board to the underside prior to drilling.
    #4 6 years ago
    ^^ Take Force Flow's advice. Drilling will nearly always result in backside splintering on any wood regardless of tool or bit unless there is a sacrificial backing material in place.
    #5 6 years ago
    Will do. Thank you.
    Did not pre-drill.
    This page was printed from https://pinside.com/pinball/forum/topic/plunge-router-splintering-plywood and we tried optimising it for printing. Some page elements may have been deliberately hidden.
