I am helping a friend restore a Paragon. We recently replaced the rectifier board with the XPin XP-BLY2518-18. The original Bally rectifier board was really crispy and had several bad pins on J1. However, the playfield GI was working with the original bally rectifier board.
Now, with the new Xpin rectifier board installed, everything works except for the PF GI. The backbox GI is working fine. We have double checked all the wiring to the new rectifier board from the transformer. One thing I thought a bit unusual - the 230v test point on the new board was at 166.8v. All the displays do work fine.
What pins should I be checking on the board for the PF GI, and what voltage should I be getting (I'm guessing 6.3 vac)?
