So I bought my first pinball a few days ago, a Terminator 2. First thing I noticed was that the drop target was stuck down (only problem I could find). At first I ignored the problem, but then got tired of all the balls constantly getting stuck under the skull... So thought I would take my first crack at fixing the machine. How hard could it be, right?
After looking around pinside it seemed to be a relatively common issue. One person had noted that the fuse F104 was blown, he replaced it, then found that the switch on the drop down target itself had to be adjusted. Problem solved!... I thought "easy enough, I can do that".
I opened the play field and noticed there was a small wire not connected, so I soldered it back on to where it looked like it should go. 20150803_192854.jpg
After that, I adjusted the screw on the drop down target because it was a bit loose - just like in the post I saw!
I then opened the back, and sure enough, F104 fuse was blown - just like in the post I saw. I purchased a 3Amp / 250V fuse and replaced the blown fuse.
Feeling good about myself, I turned on the pinball. Some random lights flashed, my heart sank, I heard some sizzling and smelled smoke. Then the cannon turned all the way to left and stopped. All the lamps were flashing, except for a few that just stayed lit (not good). The pin then said something like "Check Switch 77 - Knockdown Target". I then cried a bit inside.
Looks like the top left Transistor just melted everything around it. 20150803_193050.jpg
My first reaction is to just replace the boards with Rottendog boards, because to me (especially with my inexperience), it looks like this driver board will never work again.
I was hoping I could get some help from the all of the more knowledgeable people out there. If you could please refrain from ragging on me, I feel crappy enough as it is. Especially given that my first attempt at fixing a pinball resulted in utter failure. Some of the advice I'm looking for is:
1) Should I try to fix this board? Would that be difficult to do?
2) Do you think it was caused by a wrong fuse? I definitely used a 3 amp fuse - so I should have been good right?
3) If I do get new boards, is there a possibility this whole thing could just happen again?
4) Anything else you could advise on would be great.
Thanks in advance
