I am posting this on behalf of John...AKA "NoQuarters" He is new to pinball and bought this game last week. Any help you can give him I'm sure would be appreciated!
We have been playing the Stingray and having fun. Yesterday I changed out a bunch of stock bulbs with LED bulbs in the back glass area.
No problem, machine seemed to work fine after doing that.
Then I think I may have messed up though when I tried changing to LED in the Pop Bumpers. I left the power on and proceeded to the pop bumper lights under the plastic 1000 when lit score caps.
The LED flickered in a couple Pop bumpers so I changed them back to stock bulbs. After doing this the ball poppers and ball advance wouldn't work. Targets would not come up either when you turned off and then repowered up the machine. The 1 amp slo blow fuse under the playfield blew. We looked things over and put in another fuse. Seemed to start ok, then got an electrical smell and a small bit of smoke. Turned the machine off and found the left pop bumper was very hot at the coil assembly under the playfield. I'm guessing I burn't out the coil ? Could trying to change the bulb in the pop bumpers do this ? I noticed the light assemblies seemed to move up and down inside the bumpers as I was trying to change them. Could I have shorted something out by messing with the bulbs in the pop bumpers, or cause some kind of spike or something when trying to put LED's in there and they flickerd ? (maybe I should have put the power off changing bulbs in the bumpers? ) I have ordered a replacement coil. I am guessing some how the coil became stuck on or overheated blowing the fuse etc. Anything else I should check or do ? Thanks John
John-
My first recommendation would be to check all the fuses on the power supply/bridge recitifier board. But since you had a smell of smoke that suggests a short and the fuse will just blow again. I think you're on the right track ordering a new coil. I would look for obvious signs of melted wires, etc.
As far as the LED's in the pop bumpers go; I probably wouldn't have changed them with the machine powered on. Occasionally I have done this but it's risky. There is quite a bit of high voltage that isn't disabled on an older game.
It would probably help if you could tell us what type of LED's you were using. It may also help to take a picture of the area. Watch the thread and the forum members can decide what's best. There are people on here with far more experience then I have.
George/Morpheus1975
