(Topic ID: 56809)
Please Help.. Firepower boards
By danczaz
10 years ago
  • 216 posts
  • 20 Pinsiders participating
  • Latest reply 10 years ago by RudeDogg1
There are 216 posts in this topic. You are on page 1 of 5.
#1 10 years ago
Hello All,
I found a firepower to buy and outside of machine looks to be in good condition. I have some photos of the boards. This is being bought as a project pin. Could someone give me some general feedback. I am buying this anticipating I'll have to replace driver board and there will be other work that needs to be done. Still learning but any general feedback would be greatly appreciated!! Any severe show stoppers that pop up? (Sorry for the poor photos)
Thanks,
Dan
#2 10 years ago
Don't assume too much on that driver board, just looks dirty and aged. No biggie.
Read Vid's guide to system 3-7 bulletproofing thread. Here:
http://pinside.com/pinball/forum/topic/vids-guide-to-bulletproofing-williams-system-6
Read www.firepowerpinball.com
Learn and enjoy your new pin. Firepower is one of those pins that many people love and there are tons of parts for them.
#3 10 years ago
Thanks Patofnaud... Kind of taking a gamble on this one but I really want it for my collection so just hoping I do not get in over my head...Driving 3 hours to get it so gonna buy for sure... Been looking too long for one that is not extremely over priced to let this one slip past my finger tips...Dan
#4 10 years ago
Biggest thing on Firepowers is the playfield. They got played a LOT and a good lot of them have trashed playfields (and its hard artwork to patch in). As long as the playfield is good, everything else is easily obtainable.
#5 10 years ago
Driver board will likely need some work, but I've seen and successfully repaired far worse looking than that. Will likely need new lamp resistors, a good cleaning, and at least one or two connectors for the special solenoids. I'm totally unconcerned on the driver board.
I am a bit concerned about the CPU board. Looks like somebody put a 2716 EPROM at IC26 via a method I haven't seen before, and there's some darkening around the battery holder and diagnostic button. Again, not something I've really seen before, as it doesn't appear to be corrosion but heat damage instead, and this isn't a spot that usually suffers from heat to that extent.
However, it will definitely need the power supply either repaired or replaced. I am very unhappy with the looks of the capacitor hack that was done on there. Could be an easy re-cap job, could be a bit more involved. Definitely some creative engineering there.
Still, even with all that repair work, would come out about 1/3 to 1/2 the price of going with new boards all around.
Like the other guys said, worry more about playfield, backglass and cabinet. Every board in that machine can either be repaired or replaced at reasonable cost. The cosmetics are where restoration costs start adding up fast.
#6 10 years ago
Oh boy.. Might be in over my head on this one but after a 3h45m drive (one way) I had to pick it up... I'll post a few photos I took quickly after I loaded it in my garage...
#7 10 years ago
Cabinet
IMG-20130715-01491.jpgIMG-20130715-01491.jpg IMG-20130715-01492.jpgIMG-20130715-01492.jpg IMG-20130715-01494.jpgIMG-20130715-01494.jpg
#8 10 years ago
Backglass... Yes I dared plug it in...(Missing ground 3rd prong on plug)..The extent of what happened is lights turned on... Guy I bought from was a picker and had an old building (no electricity) that he used for storage.. Had several pins he just bought and sold as-is... What I saw was issued around fire power on back light but the detail of the moon/planent looked OK
IMG-20130716-01506.jpgIMG-20130716-01506.jpg IMG-20130716-01509.jpgIMG-20130716-01509.jpg IMG-20130716-01511.jpgIMG-20130716-01511.jpg
#9 10 years ago
One more backglass..
#10 10 years ago
Lower Playfield... Was about to walk away but... just had to get it...
IMG-20130715-01495.jpgIMG-20130715-01495.jpg IMG-20130715-01496.jpgIMG-20130715-01496.jpg
#11 10 years ago
Mid Playfield
IMG-20130715-01498.jpgIMG-20130715-01498.jpg IMG-20130715-01497.jpgIMG-20130715-01497.jpg
#12 10 years ago
Upper Playfield
#13 10 years ago
Underneath Playfield
#14 10 years ago
IMG-20130716-01497.jpgIMG-20130716-01497.jpg IMG-20130716-01498.jpgIMG-20130716-01498.jpg IMG-20130716-01499.jpgIMG-20130716-01499.jpg IMG-20130716-01500.jpgIMG-20130716-01500.jpg IMG-20130716-01501.jpgIMG-20130716-01501.jpg
#15 10 years ago
Actually had manuals...
#16 10 years ago
Not sure I even know where to start... Any help would be greatly appreciated. HHasse I'll get some better photos of the CPU and what you described above.... Any comments on the purchase?... I really wanted a Firepower but not at the going EBAY prices (yikes)... I really have not seen anything in Chicagoland area that was less than $1600. I'm beat.. hitting the sack.
#17 10 years ago
Yeah that's a project. Hopefully you got it for a good price and mice weren't living in it (they love chewing wires.)
There's no way that machine will work until you repair/replace the power supply. You need new caps and probably new diodes on the 5v line (since the fuse looks blown.) I assume you have good soldering skills and a good iron. You'll be needing them! Good luck!
viperrwk
#18 10 years ago
I just bought a Firepower back in May which had to be brought back to life. One of the reasons I bought mine is the boards had never been touched and there was absolutely no battery corrosion. As some of the other posters had stated, it's a fun game and lots of people like it.
You got the manual and schematics which are a MUST. Check all your fuses to make sure they're the correct amperage. There's a little diagram to the right of the power supply board. Don't forget the two 4 amp slow blo's on the sound boards and the 20 amp in the cabinet for the main. I removed all the boards and cleaned them. I would label the connectors. Especially the driver board. There are 12 not counting the 40 pin, which you'll have to replace, at least, the female side. If the battery holder has any corrosion, remove it and install a backbox mounted remote holder. Clean any corrosion you may find underneath with vinegar or mustard. Wipe off and coat with clear nail polish. Anything burnt, replace. Male or female connector pins. Otherwise clean the male pins. I use 90% alcohol and cheap dollar store qtips. You can also use a fiberglass eraser but nothing harsher. Those lamp resistors gotta go. The cylindrical red things on the driver board. They're toast.
With the boards off, check all the male connector pins. Some probably have cracked solder joints.
That power supply has had some "stuff" done to it. C15 filter cap should be somewhat smaller and mounted to the board under the heat sink and not in the backbox. There should only be one large filter cap in the back box. Not two.
As always, disconnect all outputs from the power supply and check your voltages before connecting the other boards.
Electronic parts. greatplainselectronics.com
Good source of tech info.
http://pinball.flippers.info/system6resources.asp
#19 10 years ago
viperwk - no mice (actually checked when I bought it if anything was chewed up). It was supposively in a guy's basement who no longer wanted it. Thanks for the advice
#20 10 years ago
dtown - Did you post anything on your restoration? Also thanks for the advice... I took a quick peak at fuses last night and definately look like some were incorrect.
#22 10 years ago
And replace the plug with a 3 prong. You save yourself headaches and zaps.
Read vid's guide.
Recap the power supply.
Clean the boards.
Replace the 40 pin inter-connector.
Clean it up and play it
Unless you want to sink a ton of money into a backglass and playfield restoration I'd get it running and enjoy the crap out of it.
#23 10 years ago
I posted a couple threads but nothing compared to the above one. Use that as your guide.
Also, if you donate $20 bucks to Clay Harrell, you'll have access to his pinballninja.com website which documents over 800 repairs. Many for System 6.
http://www.pinrepair.com/
Scroll down to the Pinball Ninja Webzine for info.
#24 10 years ago
Definitely looks like some battery juice crusties on the battery holder. Clip it off and clean up the surrounding area. Doesn't look like it has spread too much which is good. Lots of times it works its way down to the PIAs on the driver board which are directly underneath. Recapping the power supply is easy if you are decent with the soldering iron. The 40-pin is kind of a pain if you don't have a good desoldering solution. Also be sure to check the sockets on the CPU as outlined in the guides.
I just picked up a project Firepower myself but the CPU and driver are both pretty hosed with corrosion so I have to replace a whole ton of stuff. I predict you will be up and running after doing PSU/40-pin/sockets.
#25 10 years ago
This is a REALLY extensive website for Firepower (I wish every game had such a great resource).
Download the pdfs, don't try to use the strange little reader box (unless you are on a cell phone, LOL).
http://www.firepowerpinball.com/
#26 10 years ago
Quoted from vid1900:
Forgot about that one. Since the site is probably flash based it doesn't work on ios devices so I saved all the PDF's on my desktop and emailed them to myself to look at on my ipad.
#27 10 years ago
Quoted from dtown:
Good idea.
#28 10 years ago
thanks everybody!!!.. got some work to do...I'll update this thread with progress...Step one is to get her to play then I'll figure out what to do with playfield and backglass. All ready printed up the PDF's and saved even though I had manuals. This should be fun!
#29 10 years ago
If all else fails..... Williams system 3-11 replacement boards: http://www.pinballpcb.com/
#30 10 years ago
This:
And this:
That playfield and backglass don't look too bad at all.
Fix it, clean it, play it!
#31 10 years ago
Yep, I tend to think the pinballpcb (Kohout) option is the best one on the market right now.
I've also taken a liking to the Xpin power supplies, will try their displays eventually.
-Hans
#32 10 years ago
For mobile devices that can't handle the Flash home page, just point your browser to http://firepowerpinball.com/downloads
This gives you the index of all the jpgs and PDFs you can download and view on your mobile device. Sucks the homepage uses Flash but at least you can get around it.
viperrwk
#33 10 years ago
Hello All,
Got the driver board and CPU board out of back cabinet. Have some photos...
First HAN (HHASSE)
"I am a bit concerned about the CPU board. Looks like somebody put a 2716 EPROM at IC26 via a method I haven't seen before"
Here are some photos of that...
IMG-20130716-01518.jpgIMG-20130716-01518.jpg IMG-20130716-01519.jpgIMG-20130716-01519.jpg IMG-20130716-01521.jpgIMG-20130716-01521.jpg
#34 10 years ago
On the driver board for the special solenoid connection this was soldered in place..
#35 10 years ago
CPU board.. battery holder removed and back of board (I got the solder out of battery holder holes but no photo)
IMG-20130716-01523.jpgIMG-20130716-01523.jpg IMG-20130716-01531.jpgIMG-20130716-01531.jpg
#36 10 years ago
Driver Board Concerns 40 pin connection and resistors underneath
#37 10 years ago
Photo of above
#38 10 years ago
Driver Board
All resistors on right side of board
#39 10 years ago
Here is the back of Driver Board...Looks burnt up a little. Do you think this will be OK after I replace the 40 pin and all the resistors below and all the burnt of resistors on the right side???
IMG-20130716-01530.jpgIMG-20130716-01530.jpg IMG-20130716-01528.jpgIMG-20130716-01528.jpg IMG-20130716-01529.jpgIMG-20130716-01529.jpg
#40 10 years ago
Looks like you got lucky with those leaky batteries, the corrosion just appears to be around the solder holes. Make sure you sand them to get rid of the damage and neutralise with 50/50 water vinegar mix before rinsing off and drying.
Check the bottom of the back of the board too - I usually scrape a little of the green solder mask up in the areas where corrosion has occurred just to make sure none of the corrosion has slipped underneath.
The staining on the green solder mask around the battery solder holes is probably battery alkali too so make sure that is cleaned off.
You can see the failed internal metal connectors on the 40 pin interconnector on the pin at the far right and fourth from the right.
Replacing the interconnector pins and the burnt lamp resistors is the minimum you should be doing to this board but it is not possible to say whether it will be working 100% afterwards as its history is unknown.
I would strongly suggest following Clay's guides and methodically replacing/upgrading key parts as he recommends. I just get the feeling (and no offense intended) that you are expecting to replace a couple of connectors pop the correct fuses in and be good to go. If that's the case you may be in for some disappointment
Regardless of what needs to be done, Firepower is a great game and well worth the effort.
Good luck!!
Andy
#41 10 years ago
Hans doesn't have any of these cuurrently - http://www.siegecraft.us/pinball/firepoweradapter.htm - but if he did I would pull all the ROMs, cut all those jumper wires off the CPU board and install this. Perhaps he has an ETA on when he'll have more.
Your 40 pin also must be replaced as there are some bad pins there.
And you really should do power first as without good power it won't matter if the rest of the boards are working or not.
viperrwk
#42 10 years ago
Bay Area Amusements / Planetary Pinball should still have some of the adapters in stock.
But I am strongly considering another run in the near future for my own inventroy, even though I haven't quite figured out that rare comparability issue yet with early revision -6 boards
http://www.planetarypinball.com/mm5/merchant.mvc?Store_Code=PP&Screen=PROD&Product_Code=PPS-SYS346A-ADAPT
#43 10 years ago
As for the resistors, read Vid bulletproofing guide, remove those resistors all together along with the 'TIP' transistors and install SCR's and jumpers and never worry again.
As for the wire soldered on the driver board, thats a standard 'oops my connector burnt so I'll do a bypass' hack to keep the board running. Simply replace the IDC connectors/pins and you'll be all set.
Again Vid's guide details all of that.
#44 10 years ago
Oh and for the MPU chip field eco,,,,, I'd leave it alone until you find it IS causing a problem. Otherwise you run a big chance of making a problem where there was nothing more than a cosmetic one. Whoever did that 'fix' at least knew what he was doing.
Just get a remote battery holder installed, fix that driver board up, rebuild/recap the power supply and fire this sucker up. If you keep looking for problems you will find things wrong that may never have caused a problem. Just like using WebMD to figure out if that new mole is cancer,,,,,, you could end up thinking your dying when all you did was sleep on a raisin.
#45 10 years ago
Quoted from HHaase:
Weirdly Planetary has it but not BAA:
http://bayareaamusements.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=PC-SYS346A-ADAPT
As Pat says if it works after fixing the PS, 40 pin and driver board you can leave the existing ROMs but if it doesn't, I wouldn't bother swapping out all the ROMs/sockets. Hans' solution will cost only slightly more and is much less work and you'll be less likely to create more problems.
viperrwk
#46 10 years ago
Hello,
I am looking on the great plains electronics site and I found the "Williams System 3-6 Power Supply - Electrolytic Capacitor kit" and the "Connector, 0.156", Receptacle" for the 40 pin (4 -10 connectors).
For the resistors- Could someone help me clarify which product ID I should buy from great plains electronics...
From Driver Board Assembly drawing...
P/N 5A-8991 lamp cloumns resistors R149 - R156 (or everything to put in SCR's and jumpers )
P/N 5A-8984 switch row resistors R196 -R203
P/N 5A-9534 switch column resistors W9-W15
Also, For this issue with IDC connectors/pins which product ID.
"As for the wire soldered on the driver board, thats a standard 'oops my connector burnt so I'll do a bypass' hack to keep the board running. Simply replace the IDC connectors/pins and you'll be all set."
Thanks again everyone for their help... Dan
#47 10 years ago
Quoted from danczaz:
Look close at Vid's guide to bulletproofing, he shows a really clean way to totally remove those resistors and transistors thus cutting down on a TON of heat and adding a lot of reliability. I was pretty sure he showed part numbers.
#49 10 years ago
So for P/N 5A-8999-1 lamp columns resistors R149 - R156 I am just going to do this as VID recommended..
"Or, if you want to, you can replace the 8 TIP42 lamp matrix transistors (Q63, 65, 67, 69, 71,73, 75 and Q77) with IRF9Z34N MOSFETs"
P/N 5A-8991resistors R165 - R195 under 40 pin (Which one do I use?)
Drawing says: Resistor, FC, 4.7K Ohm 10% 1/4 W
Is this OK...
Product ID: RCF1/4-4.7K
Resistor, 4.7K Ohm, 1/4W, 5%
Resistor, Carbon Film, 4.7K ohm, 1/4 Watt, 5%
Color Code: Yellow, Violet, Red, Gold
http://www.greatplainselectronics.com/proddetail.asp?prod=RCF1/4-4.7K
Not sure what to use here
Drawing: Resistor, FC, 1K Ohm 10% 1/4 W
Is this OK?
Product ID: RCF1/4-1K
Resistor, 1K Ohm, 1/4W, 5%
Resistor, Carbon Film, 1K ohm, 1/4 Watt, 5%
Color Code: Brown, Black, Red, Gold
http://www.greatplainselectronics.com/proddetail.asp?prod=RCF1/4-1K
Dan
#50 10 years ago
Is this OK...
Are you using the original schematics or the one's from Firepowerpinball.com. The original's specify these as R204-R211 which are 330k ohm 1/4 watt resistors. Break out the book and take a look.
http://www.greatplainselectronics.com/proddetail.asp?prod=RCF1/4-330K
I don't know what was going on with the schematic from the website but the original does not specify any part location on the driver board as beginning with a "w".
Is this OK?
Dan
These look like the correct resistors. The only difference is the factory one's allowed a 10% tolerance while Great Plains are 5%. Just to be safe I'd shoot Ed from Great Plains Electronics an email simply asking about the tolerance level but I think you'd be good with those. A link is on the home page.
Look at my note in your quote concerning the unknown resistor.
Trade
Machine - For Trade
Washington Court House, OH
$ 170.00
Displays
Digipinball Shop
$ 12.50
RoyGBev Pinball
2,900 (OBO)
Hawesville, KY
$ 65.00
1,400 (Firm)
Benton, PA
Tools
Pincoder Store
$ 42.95
600 (OBO)
Casper, WY
$ 27.95
This page was printed from https://pinside.com/pinball/forum/topic/please-help-firepower-boards and we tried optimising it for printing. Some page elements may have been deliberately hidden.
