(Topic ID: 87863)
Please Help; Data East WWF Royal Rumble Flippers
By ShootAgainDave
5 years ago
  • 15 posts
  • 4 Pinsiders participating
  • Latest reply 5 months ago by svendmute
#1 5 years ago
Hi!
Longtime pinball player and longtime Pinside message boards reader/follower. But I'm a new Pinside member and I may have a "noob" question. I have a WWF Royal Rumble pinball. Everything works fine except for the flippers. They are activated even on "attract mode". Yes, I have the Operator's Manual but the small parts of the pages I need to check for this problem are blurry. Any help would be VERY appreciated.
Dave
#2 5 years ago
Power probably runs through a relay. Check if it's magnetized, transistor driving it failed and locked on. Things like that.
The relay would have a plastic cover and be mounted on a circuit board.
Someone with a WWF may be able to help more, pictures or something.
LTG : )™
#3 5 years ago
Sounds like you have a bad transistor or two on the flipper boards. I'd start by testing those.
#4 5 years ago
Quoted from hawkeye11:
By activated, do you mean still flip when the game is off, or they are locked in the up position ?
If locked in the up position, please follow hawkeye11's advice.
#5 5 years ago
If i'm reading this right they are activated on power-on and in attract mode. Which I think is almost always those transistors. I probably learned that from LTG back on RGP.
#6 5 years ago
Thank you guys, I appreciate!
To *LTG* - I mean they still flip when the game is off/attract mode.
Dave
#7 5 years ago
Lets make sure were clear here. The flippers are up when the game is off? Or they go up when you turn the game on?
#8 5 years ago
I mean; When I turn the power on, if I press the flipper buttons, they activate like in a normal game.
#9 5 years ago
But the game is still on "Attract Mode"
#10 5 years ago
Ok. So they work fine in gameplay, but they are still activating in attract mode. Not sure what would cause that. I thought you meant they would energize, without hitting the buttons, when you turn the game on.
#11 5 years ago
Yes - That's what I mean.
#12 5 years ago
Quoted from ShootAgainDave:
Then find the relay they run through.
LTG : )™
#13 5 years ago
Where should I start?
#14 5 years ago
That relay is on the CPU board.
5 years later
#15 5 months ago
So did you fix the issue?
My Baywatch is having a similar issue so would like to hear what your issue was…
Gweem's Mods
Professor Pinball
Plainfield, IL
$ 26.50
Hardware
Filament Printing
