hi everyone, im looking for some help if possible please .
i bought a playmatic 1977 the 30's pinball as i loved the theme of it with the one arm bandit reels, it was bought a s anon working project, it was very clean inside and out so took a gamble on it.
nothing worked, no credit no game start nothing so i decided to take all the 3 boards out and started over a few weeks cleaning every single connection and contact, replaced all bulbs and even bought a new play-field rubber set confident that it had to work after painstakingly cleaning and checking every connection.
how wrong i was, put it all back together switched it on, all or nearly all play-field lights lit up so was a good start.
pressed the credit switch on the door and i got a click and a credit turned on the back glass
pressed the start button and another click, then the coil for kicking the ball into play keeps going and what i believe is the score drum keeps rotating, some of the switches on the play-field work and make the reels spin etc and the flippers work, but its not playable at all and the game over is lit all the time, i do recall a disc part on the bottom board, could be for the balls left in play but not sure was slack and i do not know how to set it into the correct place, i tried it in a few different locations and its made no difference.
do you think it could be that ? or something totally different ?
thank you for reading and i appreciate any help at all
