I think this may have been covered before, but has anyone encountered a playfield being warped/bowing slightly after being stored for years? I'm guessing thats not natural, but is this something that's fixable so the playfield can still be used?
If the playfield has no side rails on it, it will almost certainly have some bow after storage.
I've bolted Angle Iron to the underside of a bowed playfield - works great.
Pics needed.
I did some measuring and the curve appears to be under 3/8 of an inch....so I guess not much? Hopefully once side rails get screwed on and some of the weight gets put on from things it will even out a bit...the curve is pretty much dead center of the PF
If you have time (took a month or so) ...and depending of where or how big bow is
In a Small room I have laid PF flat face side down with a slight even (protected) shim to each side or where needed to reverse bow and every day i would go in with a spray bottle on mist and give a few squirts to raise humidity in room. Every few days i would also take shims out and and just lay flat and keep alternating this till it was flat.
It has been a year since i have done and PF is still flat out of game.
This page was printed from https://pinside.com/pinball/forum/topic/playfield-warpingbowing and we tried optimising it for printing. Some page elements may have been deliberately hidden.
