(Topic ID: 294746)
Playfield Swaps
By dmacy
2 years ago
  • 1 post
  • 1 Pinsider participating
    This topic is linked to a classified ad.
    The Ad Listing has been ended, so this topic closed automatically.
    #1 2 years ago
    ARCHIVED
    Archived ad
    Pinside keeps a record of old ads in its Market Archive, for historical purposes and as a price reference. This ad has been ended by its seller and is now archived.
    Other items - for sale
    Playfield Swaps
    Added: 2021-04-26 22:00:00 UTC • Re-listed: 3 times (August 31st, 2021) • Ended: November 4th, 2021
    Price
    $ 750
    Performing playfield swaps for Bally Williams System 1, WPC, WPC95 and newer along with Stern and JJP. Older titles please contact me first. I also will do extensive shop jobs that entail a full tear down of the entire playfield and rebuild. Pricing starts at $750 for a bare bones swap. Full "real" shop jobs that remove everything from the top and rebuild/replace worn on the bottom side depends on the title. Please contact me.
    Hardtops: I will do these if you prepare/clear the playfield for it. I'm not set up to paint or to do a proper sanding.
    My typical swap is a full tear down of every part and assembly including cleaning and polishing of small parts. You provide the playfield and the parts you want swapped. I'll tear down and advise of what is found broken including pictures. There's always something broken! Wear parts like coil sleeves, switches and related get replaced. I generally recommend getting new wooden side rails, plastics and ramps when they're available. Cleaning of all harnesses. Other details such as coil wrappers, mods, LED's, etc can be added. Prices range from $750-1000+ depending on what is done, etc. I can provide the parts or you can.
    Most of my swaps and shops are documented here on Pinside. Here are a few:
    STTNG: https://pinside.com/pinball/forum/topic/sttng-a-refresh-for-future-generations
    Bad Cats: https://pinside.com/pinball/forum/topic/bad-cats-playfield-swap-ii-youre-one-bad-cat
    AFM: https://pinside.com/pinball/forum/topic/attilla-from-mars-another-afm-playfield-swap
    AFM Kruzman: https://pinside.com/pinball/forum/topic/afm-mirco-playfield-gone-over-by-kruzman-swap
    BK2000: https://pinside.com/pinball/forum/topic/bk2000-refresh-redeux
    Whirlwind: https://pinside.com/pinball/forum/topic/another-whirlwind-playfield-swap-refresh-cpr-gold-second-run
    EATPM: https://pinside.com/pinball/forum/topic/elvira-and-the-party-monsters-playfield-swap-refresh
    Whirlwind: https://pinside.com/pinball/forum/topic/playfield-swap-from-wind-chapped-to-whirlwind-reset-in-time#post-4540566
    CV: https://pinside.com/pinball/forum/topic/cirqus-voltaire-refresh-cabinet-and-playfield-swaps
    CFTBL: https://pinside.com/pinball/forum/topic/cftbl-pulling-play-field-and-sending-out-to-be-touched-up-and-cleared#post-3522122
    Avatar: https://pinside.com/pinball/forum/topic/from-avaturd-to-avatar-machine-refreshextensive-shop
    Fire!: https://pinside.com/pinball/forum/topic/fire-refreshteration-pf-swap-and-a-general-spruce-up
    Bad Cats: https://pinside.com/pinball/forum/topic/bad-cats-cpr-gold-playfield-swap-meow
    FH: https://pinside.com/pinball/forum/topic/another-funhouse-playfield-swap-3
    HS: https://pinside.com/pinball/forum/topic/high-speed-cpr-playfield-swap
    GL: https://pinside.com/pinball/forum/topic/grand-lizard-hardtop-playfield-rebuild#post-6035497
    Banzai Run: https://pinside.com/pinball/forum/topic/banzai-run-playfield-set-swap
    Joker Poker Kruzman: https://pinside.com/pinball/forum/topic/no-joke-joker-poker-solid-state-kruzman-playfield-swap#post-6217435
    Earthshaker Shop: https://pinside.com/pinball/forum/topic/earthshaker-deep-fault-cleaning-amp-refresh#post-6264807
    Please contact me for pricing/request. Turnaround is generally a 2-4 weeks depending on the title and parts flow. I usually only work on one or two at the time max.
    Item photos
    No images have been added to this ad listing yet.
    No photos have been uploaded for this ad.
    Contact
    Note! This is an archived ad. No longer for sale!
    Seller insights
    These are dmacy's market stats.
    All ads
    0
    87
    Archived ads
    16
    62
    Success
    53
    34
    Feedback score
    19
    100.0%
    Go to dmacy's stats page
    Listing result
    The seller marked this ad as "not sold". The item did not sell through Pinside so there's no listing result.
    Item location
    Reading, PA, US
    This page was printed from https://pinside.com/pinball/forum/topic/playfield-swaps-2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
