Archived ad
Pinside keeps a record of old ads in its Market Archive, for historical purposes and as a price reference. This ad has been ended by its seller and is now archived.
Price
$ 750
I am slowing down on how many I do but had some cancellations so have some time to get one or two done in the next few months.
Performing playfield swaps for Bally Williams System 1, WPC, WPC95 and newer along with Stern and JJP. Older titles please contact me first. I also will do extensive shop jobs that entail a full tear down of the entire playfield and rebuild. Pricing starts at $750 for a bare bones swap. Full "real" shop jobs that remove everything from the top and rebuild/replace worn on the bottom side depends on the title. Please contact me.
Hardtops: I will do these if you prepare/clear the playfield for it. I'm not set up to paint or to do a proper sanding.
My typical swap is a full tear down of every part and assembly including cleaning and polishing of small parts. You provide the playfield and the parts you want swapped. I'll tear down and advise of what is found broken including pictures. There's always something broken! Wear parts like coil sleeves, switches and related get replaced. I generally recommend getting new wooden side rails, plastics and ramps when they're available. Cleaning of all harnesses. Other details such as coil wrappers, mods, LED's, etc can be added. Prices range from $750-1000+ depending on what is done, etc. I can provide the parts or you can.
Most of my swaps and shops are documented here on Pinside. Here are a few:
STTNG: https://pinside.com/pinball/forum/topic/sttng-a-refresh-for-future-generations
Bad Cats: https://pinside.com/pinball/forum/topic/bad-cats-playfield-swap-ii-youre-one-bad-cat
AFM: https://pinside.com/pinball/forum/topic/attilla-from-mars-another-afm-playfield-swap
AFM Kruzman: https://pinside.com/pinball/forum/topic/afm-mirco-playfield-gone-over-by-kruzman-swap
BK2000: https://pinside.com/pinball/forum/topic/bk2000-refresh-redeux
Whirlwind: https://pinside.com/pinball/forum/topic/another-whirlwind-playfield-swap-refresh-cpr-gold-second-run
EATPM: https://pinside.com/pinball/forum/topic/elvira-and-the-party-monsters-playfield-swap-refresh
Whirlwind: https://pinside.com/pinball/forum/topic/playfield-swap-from-wind-chapped-to-whirlwind-reset-in-time#post-4540566
CV: https://pinside.com/pinball/forum/topic/cirqus-voltaire-refresh-cabinet-and-playfield-swaps
CFTBL: https://pinside.com/pinball/forum/topic/cftbl-pulling-play-field-and-sending-out-to-be-touched-up-and-cleared#post-3522122
Avatar: https://pinside.com/pinball/forum/topic/from-avaturd-to-avatar-machine-refreshextensive-shop
Fire!: https://pinside.com/pinball/forum/topic/fire-refreshteration-pf-swap-and-a-general-spruce-up
Bad Cats: https://pinside.com/pinball/forum/topic/bad-cats-cpr-gold-playfield-swap-meow
FH: https://pinside.com/pinball/forum/topic/another-funhouse-playfield-swap-3
HS: https://pinside.com/pinball/forum/topic/high-speed-cpr-playfield-swap
GL: https://pinside.com/pinball/forum/topic/grand-lizard-hardtop-playfield-rebuild#post-6035497
Banzai Run: https://pinside.com/pinball/forum/topic/banzai-run-playfield-set-swap
Joker Poker Kruzman: https://pinside.com/pinball/forum/topic/no-joke-joker-poker-solid-state-kruzman-playfield-swap#post-6217435
Please contact me for pricing/request. Turnaround is generally a 2-4 weeks depending on the title and parts flow. I usually only work on one or two at the time max.
Item photos
No images have been added to this ad listing yet.
No photos have been uploaded for this ad.
Contact
Note! This is an archived ad. No longer for sale!
Seller insights
These are dmacy's market stats.
Listing result
The seller marked this ad as "not sold". The item did not sell through Pinside so there's no listing result.
