Looking for some advise. I recently did a playfield swap on my Abra Ca Dabra. Before I did the swap, everything was running perfect. I had no issues with the swap. I used the same screws etc... My issue is, as soon as I load the ball, it keeps scoring 5,000. Here is what I've check: every switch to see if it is grounding out. The tabs on the switch making sure they are not touching. I've checked the ground wire to see there are any issues. I've touched everything switch on the playfield and in the drop targets to see if they stuck somewhere. All this checks out. Ive had the game on and while it is scoring 500, I started unsoldering switch by switch, but still couldn't find the problem (I have to admit, I gave up on unsoldering ALL the switches). Any other suggestions on things to try? Thank you for any ideas.
