First question for my first ever playfield swap;
So I've stripped off as much as I can and I was about to make a start but during my preparation look-over the two playfields (new and existing) I have noticed some drill-holes off-center, these are for the wire ball 'guides' as such pretty important to be spot-on (I would have thought).
Does this matter? - The holes are correct distance for the wire guide to fit, but will it then be slightly out of place?
Do I leave these to last, to make sure they line-up?
Also the holes are too small so I will need to drill them a little so do I use the actual hole and make it bigger or put a hole in the center of the art work?
