(Topic ID: 293911)
Playfield swap
By Vin-bot
12 months ago
  • 20 posts
  • 11 Pinsiders participating
  • Latest reply 11 months ago by pinhead52
#1 12 months ago
Getting ready for my playfield swap (never did this before). I thought I would share my plan of attack to see if any of you experienced guys got any comments or tips you like to share.
My plan of “attack”:
1
Apply (staple) new GI wire on new playfield, using the old playfield as a guidance.
2
Bring over the light sockets from the old playfield and solder them to the new GI wire
3
Bring over and solder the pop bumpers
4
Detach (unscrew) everything from the old playfield and a slide cardboard sheet underneath
5
Bring the cardboard with all parts over to new playfield and one by one screw everything on to the new playfield
What are your thoughts on this?
#2 12 months ago
Main thing is before u even start anything take lot and lot of pics of everything from on end too the other top and bottom ,plus what I do is too make up a form board then draw out the playfield it self just so u can put all the parts where they go so u don't lose them and too know where they go ,then I tape and mark all parts too ,if anything u can always go back too the pics if u get lost
#3 12 months ago
When I did my first swap not only did I take tons of photos but I stuck the parts in ziplock bags with the order number of removal. So I may start with the right sling, that would be bag one and the left bag two. When reassembling I would just reverse order. Had about 60 numbered steps.
#4 12 months ago
Look through some of the HEP thread and other restoration threads where playfield swaps have been documented. The tips in those threads are invaluable.
Don't forget about using tracing paper for dimpling and drill holes and keeping track of the t-nut sizes.
#5 12 months ago
Not sure how different a PF swap is between an 80’s Williams and a 70’s Gottlieb, but here’s a couple pics from my recent swap. I drew a rough sketch of the underside PF components on cardboard and used that to keep all the screws that hold everything down. Then I pulled all the staples, placed the new PF next to the old, and slid everything over a little at a time.
I drew the GI wiring on the cardboard too-in a different color-to help with getting that in the right spot. Restapled the wiring and screwed the components back down.
I’m sure I’m forgetting a bunch of details and I’m not good at taking “in progress” pics, but hope this helps.
09208132-9C57-44AF-B620-493D1ED3F714 (resized).jpeg145BA541-A347-40D8-9064-83FC811D1319 (resized).jpeg6FE6125B-E38C-41FC-B5D6-8B796B727FE3 (resized).jpeg722A18DB-7C85-4884-B3BC-394467A54898 (resized).jpeg
#6 12 months ago
I agree that you need to document the crap out of it and be methodical. That really does make it go smooth.
#7 12 months ago
In addition to the steps above with tons of pictures, notes, labeling, you’re going to want to clean and rebuild mechanisms before transferring to the new playfield.
So flipper assemblies, pop bumpers, drop targets will all need to be desoldered and disassembled.
You really should remove and clean the wire harness too.
#8 12 months ago
Thanks for the very handy tips.
I can’t seem to find what the correct t-nut size is that’s used on the playfield of my machine (got a Pinbot)
#9 12 months ago
Quoted from Vin-bot:
Usually #6, #8 or #10. See what size screw fits there.
#10 12 months ago
Quoted from emsrph:
I am not familiar with the imperial system.
I checked and found that the bolt used for the star posts is the correct size.. this shaft is 2-2,5mm.
#11 12 months ago
Would that equal a #6 t-nut?
#12 12 months ago
Most likely.
#13 12 months ago
Cool thanks..
Finalizing my parts list for ordering, but I can’t seem to find the playfield plastic glass channels
The blue parts manual does not show part numbers for this. Can anyone tell me the part number so I can order them?
Especially the back end one seems to be unfindable for me. I found the foam, but the t-shaped plastic channel, I can’t find.
#14 12 months ago
Cool thanks..
Anyone?
#15 12 months ago
I wouldn't bother reusing the old lamp sockets. I would install all brand new sockets for reliability.
#16 12 months ago
For sides look here:
https://www.pinballlife.com/playfield-glass-side-rail-plastic-channel.html
I used that on Elvira. It should work on PinBot.
For the back, maybe this:
https://www.pinballlife.com/playfield-glass-rear-plastic-channel.html
Might want to email and find out.
Make sure you clean any and everything that goes from the old playfield to the new. Consider tossing old light sockets because in a PinBot they are about 35 years old. Look at some of dmacy 's most excellent swap threads. Use Pinside as a resource. Make a thread, document your process, ask questions, and LISTEN to experience.
Read through these threads:
https://pinside.com/pinball/forum/topic/vids-guide-to-ultimate-playfield-restoration
https://pinside.com/pinball/forum/topic/vids-guide-re-populating-playfields
https://pinside.com/pinball/forum/topic/cleaning-playfield-harnesses-vids-guide
https://pinside.com/pinball/forum/topic/vids-guide-to-upgradingrebuilding-flippers
https://pinside.com/pinball/forum/topic/cabinet-restoration-vids-guide
https://pinside.com/pinball/forum/topic/pinbot-fans-and-owners-club
https://pinside.com/pinball/forum/topic/vids-guide-to-rebuilding-pop-bumpers/
Be prepared for this to take months and take your time.
#17 11 months ago
Quoted from alexmogil:
I searched for replacement sockets (the blue parts book came in really handy here), but some of the socket types are currently not available at the various online pinball parts stores..
I was reading about cleaning harnesses in the dishwasher (incl. sockets) and I am thinking of cleaning the sockets instead of replacing them
#18 11 months ago
REPLACE THEM! Do a little more digging, they should all be available. If there is a style you cant find, post a pic here and we will steer you to the source.
And Im dealing with cloth harnesses on EMs shutter at the though of washing the harness.
Currently I have 4 harnesses in big heaps in boxes, the pf restorer guys/gals take too long. Not having documented any of it... once you do 20+ pf swaps it gets a lot easier.
#19 11 months ago
Quoted from pinhead52:
Okay, I can’t find these ones:
A-8449
A-8338
does anyone know where to find these sockets?
#20 11 months ago
for the 8449 pbr offers the 2916 with the extra insulated tab for diode. You just flatten the tab and it will fit the bill. Steve will sell you diodes separately.
for the 8338 it looks like the 1/2 bracket 4762 from pbr
http://www.pbresource.com/sockets.html
$ 17.00
$ 54.99
3,000 (OBO)
Shady Side, MD
$ 12.00
Barnegat, NJ
$ 44.99
Pinball Shark
Dallas, TX
Various Other Swag
JK Pinball
$ 39.99
