(Topic ID: 227412)
Playfield safe cleaner
By Jwblocal701
5 years ago
  • 14 posts
  • 9 Pinsiders participating
  • Latest reply 5 years ago by ChrisLIX
    #1 5 years ago
    So I need to clean my playfield
    Haven’t done it in a while.
    I like using carnuba wax
    But what’s safe to wipe it all done with first.
    Obviously it’s like a car
    You don’t run wax onto a dirty area first without cleaning it
    Anything local I could get to spray on and wipe playfield down with
    #2 5 years ago
    For light general cleaning Novus 1 works great.
    #3 5 years ago
    Quoted from Only_Pinball:
    Thats what I use also. Then wax. Works well
    #4 5 years ago
    Ok I thought novus 1 was a polish more than a cleaner.
    The current carnuba is black and dirty on my PF so wanted to clean it off
    Wasn’t sure if like simple green or anything like that was good to use
    Then a fresh coat of carnuba wax
    #5 5 years ago
    Keep away from anything water based if you can. Water will raise the woodgrain and can cause planking.
    I think generally, the safest accepted cleaning product to use on a playfield is Naphtha, as it won't harm the paint, any clear coats (be it lacquer or automotive style), is non abrasive, and since it doesn't have water in it, it won't cause planking. Plus it'll remove old wax residue, leaving your playfield fresh and ready to accept a new coat of wax. Just keep the stuff away from mylar, as it'll breakdown the adhesive.
    #7 5 years ago
    I like to clean my safes with Leftfield safe cleaner.
    #8 5 years ago
    Yes I read his tips
    But didn’t have what I was looking for really.
    Was mainly looking for what to clean all the old wax off and make it nice and clean before applying new wax
    Guess I’ll just use the novus 1
    #9 5 years ago
    Quoted from Jwblocal701:
    Yes I read his tips
    Want to clean off the wax completely, use naptha. He talks about it in every other post.
    #10 5 years ago
    Naphatha should be your go-to. Don’t mess around with Novus 1 for this type of thing. Novus 1 is going to be more expensive, and FAR less effective at removing wax residue—if it’s even effective at all. Naphtha’s job is literally to dissolve wax, and it leaves absolutely no residue. Use it with a nice terry cloth, and you’ll be in business.
    Save the Novus 1 for your ramps and plastics.
    #11 5 years ago
    Quoted from mbaumle:Naphatha should be your go-to. Don’t mess around with Novus 1 for this type of thing. Novus 1 is going to be more expensive, and FAR less effective at removing wax residue—if it’s even effective at all. Naphtha’s job is literally to dissolve wax, and it leaves absolutely no residue. Use it with a nice terry cloth, and you’ll be in business.
    Got cha
    #12 5 years ago
    Nap or Novus 2.
    #13 5 years ago
    Yes I read his tips
    Right on the first page:
    https://pinside.com/pinball/forum/topic/cleaning-and-waxing-pinball-machines-vids-guide#post-2656104
    4 months later
    This page was printed from https://pinside.com/pinball/forum/topic/playfield-safe-cleaner and we tried optimising it for printing. Some page elements may have been deliberately hidden.
