(Topic ID: 304926)
Playfield restoration
By joshmc
2 years ago
  • 12 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by joshmc
    #1 2 years ago
    Hi All,
    Well, I’ve completely f@&ed my playfield. Last week, I had it clear coated. Took it to someone who has their own professional spray booth. They used a 2 pac clear coat then baked it for 10-15 mins. It looked unreal. Took it home and after a couple days I gave it a wet sand with 600 grit. Problems started when I laid down the frisket (and Oramask), the clear started to lift off the playfield. I forged ahead and laid down one of the colours with my airbrush. After the Createx dried, some stuck to the playfield but parts were lifting off. The paint stuck to the clear but the clear was lifting off the playfield. I’d really appreciate some advice.
    I’ve put so much effort into this restoration only to see this happen
    00651153-59C7-4DCF-8B70-1F3C51A8479D (resized).jpeg00651153-59C7-4DCF-8B70-1F3C51A8479D (resized).jpegE26B2EC1-6013-429B-B88A-542BF66DE461 (resized).jpegE26B2EC1-6013-429B-B88A-542BF66DE461 (resized).jpeg
    #2 2 years ago
    What temp did they bake it? Usually all I hear on here is non accelerated drying. Wonder if that caused some issue. Let’s let others chime in but if the foundation clear isn’t adhering to the playfield, I’m not sure doing anything above it will help.
    #3 2 years ago
    The playfield needed to be prepped properly before getting the clear coat. Cleaned thoroughly and scuffed with a red scotch brite. The clear needs something physical to bond to.This might have been done, I can’t tell from the pictures. When you sanded the playfield, you basically opened up the clear to gas out more. This can have a reaction with the glue used for the masking materials. It is better to wait a few days after sanding before applying masking materials. Playfield should be cleaned again before applying masking and the masking materials should be removed as soon as possible. Another thing I would suggest is to get away from using sandpaper that needs to be used wet. There are plenty of sandpaper types used in automotive refinishing that work just as well dry. No need to introduce moister to your wood playfield.
    #4 2 years ago
    Quoted from trilogybeer:
    I’ve resprayed, this time using 2pac in a can. I’ve noticed the finish is not as smooth as the first attempt with a HVLP gun. What would be the best thing to use to smooth it out before airbrushing?? Scotchbrite pad? 600, 800 grit sandpaper?? Dry? Wet!
    #5 2 years ago
    Make sure you spray within the range given by the manufacturer. If you are too far away or don’t lay enough down you may get orange peel.
    I use 600 or 800 grit dry to sand between coats.
    #6 2 years ago
    600 grit dry. I also just noticed, were the wood rails on the sides of the playfield left on when it was clear coated? Those should have been removed. The screws for the pop bumper coil mounting brackets should have been removed also. If stuff like that is left on and just clear coated over or around it will cause problems.
    3 weeks later
    #7 2 years ago
    Playfield finished and ready for clear. Decals will be applied after that. Then another clear.
    44534340-85E0-4754-BC5E-57D51EEC5A1F (resized).jpeg44534340-85E0-4754-BC5E-57D51EEC5A1F (resized).jpeg5E09249C-04DA-4B8C-8FDB-BE5A27FB47C7 (resized).png5E09249C-04DA-4B8C-8FDB-BE5A27FB47C7 (resized).pngB3E73967-C780-4711-B152-CB18EBFA393F (resized).jpegB3E73967-C780-4711-B152-CB18EBFA393F (resized).jpegE22FA7B3-6071-4B5C-8288-10445D7B028E (resized).jpegE22FA7B3-6071-4B5C-8288-10445D7B028E (resized).jpeg
    #8 2 years ago
    Looking really good. I know how much time and effort this requires.
    I would recommend taking off the wood side rails too.
    I'm stripping down a playfield that someone cleared 10 years ago, There was a lot of clear that was under those wood side rails and it continued to bleed out after they sprayed it. So it messed up that corner and wasn't a smooth finish.
    #9 2 years ago
    Major improvement. It’s looking great.
    1 month later
    #10 2 years ago
    Apron powder coated and decals applied. Plastics added to playfield. Coming together
    49D3DED3-173F-4C25-872F-190B1F177ACF (resized).jpeg49D3DED3-173F-4C25-872F-190B1F177ACF (resized).jpeg5668EAD3-DF17-4DA4-AD5E-779FA1A8F59D (resized).jpeg5668EAD3-DF17-4DA4-AD5E-779FA1A8F59D (resized).jpeg7CA1D8AC-3C05-4442-AC44-802493E31DE0 (resized).jpeg7CA1D8AC-3C05-4442-AC44-802493E31DE0 (resized).jpeg
    #11 2 years ago
    Very nice work, looks great!
    #12 2 years ago
    Quoted from Garrett:
    thank you!
