(Topic ID: 258326)
Playfield lights stuck on
By robey99
62 days ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 55 days ago by robey99
#1 62 days ago
I finally tore down and shopped my Indy500. I put back together and the play field lights are stuck on. I checked all the connections and replaced the display, driver and cpu boards with new ones. All fuses good. Still nothing is working. I am at a loss and did lots of research and cannot find anything. Appreciate any thoughts on next steps to check. Thanks.
#2 62 days ago
All connectors in the correct spots ? Facing the right direction ? Ribbon cables red stripe pin one each end ? Not off by a row ?
If it was okay before. Then something changed when you reassembled it.
#3 55 days ago
Thanks but I have triple checked all the connections and no luck. I have tried researching this issue extensively and I cannot find any topics on pkayfiels lights being stuck on. I can’t believe this is not a common issue.
$ 49.95
Pin Stadium Pinball LEDs
PinWoofer
