Sounds like they want you to use a little Novus 2 and then wax it but everybody will have their own technique. There's a thread on it...
https://pinside.com/pinball/forum/topic/cleaning-and-waxing-pinball-machines-vids-guide
Quoted from SLCpunk2113:I usually do some simple green then some wax but I'm guessing just skip the simple green step?
Checkout that vid guide, there are actually some differences based on the type of playfield--System 11 games vs later ones or whatever.
Having said that, in general, I usually spray Novus 1 on a rag and then do an initial wipe down with that, then take the more abrasive Novus 2 and go over any problem areas...then Novus 1 it lightly to get any residue...then a couple coats of carnuba wax.
Simple green seems like it would contain water...I use it to clean metal parts.
Quoted from Wickerman2:Checkout that vid guide, there are actually some differences based on the type of playfield--System 11 games vs later ones or whatever.
Same for us. Novus No1 then Novus no2. Only difference is we now fit Playfield protector. No carnuba wax any more.
All the info in that note is everything anyone with basic knowledge would NOT do anyway. Some good advice has been given plus Vid's thread is all you need to know.
I would not use Novus products on this era playfield. Simple Green is fine. Spray it on the rag, not the playfield. Then follow it up with wax.
Don't use Simple Green on that era playfield!!!! It contains water and soap, exactly what Bally was warning you NOT to use.
C'mon guys......
Quoted from vid1900:Don't use Simple Green on that era playfield!!!! It contains water and soap, exactly what Bally was warning you NOT to use.
C'mon guys......
Told you to read the guide! Busted!
This page was printed from https://pinside.com/pinball/forum/topic/playfield-cleaning-warningbally and we tried optimising it for printing. Some page elements may have been deliberately hidden.
