Some of you know I am a complete NUT when it comes to keeping my playfields sparkling. I just wanted to share what I do to maintain them as I always see discussions on what is the best cleaning/polishing setup.
This is my method to produce mirror finishes that don't leave ball trails.
(PS this picture was taken with a shit camera).
// Error: Image 27891 not found //
I start by cleaning the playfield initially with Novus 2 as most of us do. Its a very good for cleaning and stripping any existing wax or buildup. However be gentle with it as it is a bit abrasive and NEVER use it in a circular pattern. Those of you with Black cars understand the reason behind this. SWIRL MARKS! (No wax on wax off Daniel san) Gentle back and forth removes most anything unless its really grimy.
Then I move on to the wax.. Most of you use Mothers which is a good wax but you also have to make sure you are using the right one.
Some people buy this one:
This is the WRONG wax as it has a built in compounding agent. That's why its called a "cleaner wax"
If there is a mothers you should use, its this:
Pure Brazilian Carnauba wax. This however is also misleading as its only 60% Carnauba. The rest are binders and polymers used for adhesion.
The wax I use while about 20 dollars more than the Mothers is 100% pure Carnauba. This helps leave zero film on after removal and you don't get any ball trails as those are essentially marks in the finish which have to be rubbed out and then subsequently reapplied.
Enter.. P21S:
Finally between full waxing's I use something a bit unorthodox which some may know of but I use in lieu of Novus 1 and its called Brillianize.
http://www.brillianize.com/index.html
It cleans whatever surface dirt sit's on top of the P21S without removing it leaving a ridiculous mirror shine. It's also great as you can figure on any plastics and even metal pieces.
Now if you find yourself with black grime in places like the shooter lane, invest in some claybar. The automotive guys know all about it. It's great for removing just about anything from a paint surface..
Using the Brillianize as a lubricant rub the claybar over the surface dirt and watch it come right up. I'd use this over Mr Clean Magic Eraser because if used improperly the eraser will take a layer of clear or paint with it.
Please NO flame wars as to why this product and that product sucks. This post is meant to be informative as to how I maintain machines, nothing more
