I recently acquired a Mars Trek (2nd pin, first EM) and it has an odd issue. When I hit start, the "3-player" spot on the backglass lights up, and pulsates. After a few seconds it switches to "2-player", which pulsates. After a few seconds it switches to "1-player", pulsating, then solidly lit. At this point I can mostly play a game (scoring might be a little wonky, but 1 issue at a time here). I can hit start again to switch to "2-player" (no pulsating, just solid), or 3 player. I can mostly play a 3-player game with no issue.
If I hit start once, and the "3-player" lights up, and I hit start again, it will go straight to "4-player", solidly lit. Typically, if I go that route, it will play through players 1-3 normally, then it will give infinite ball 1's to player 4.
After combing through the machine, I see 2 wires that are disconnected. The first is in the backbox - some yellow wires that should be attached to a switch on a scoring reel, which came loose. I'll be resoldering those tonight. The 2nd is a grey wire (looks aftermarket) attached to the switches on the white plastic wheel inside the cabinet. I don't really know where this should go. Also not sure if it's related to my current issues.
Obviously I'm still learning, but any help would be appreciated
