"There's a good ground and I can't follow it without cutting alot of wire bundles. If i knew where the coin unit disc was I'd check the voltage there. thanks"
This is a guess, but I think the "coin unit disk" sends a signal to a chip ever time you put a quarter in (in pay mode) or every time you push the credit button (in free play mode). There for being connected to all the player lights, so testing from there wont do any good, it still powers or tells programing to power the other 3 player lights.
From the termolgy being used I'm also guessing the "coin unit disk" is on the coin door. Look and see if any of the wires connected to the coin door match the color of the wire coming from the non-working light. Again, just guessing.
