Playboy and Coke - now that funny.
Anyway - I ordered replacement sockets and replace anything and everything acid touch and re-soldered everything. I used vinegar and isopropal alcohol to clean EVERYTHING off first. Sanded down all the traces and followed them all under a powerful microscope and "thought' I got everything cleaned up well.
I installed the boards and although everything powered up - the game still sat there and wouldn't start the game.
Frustrated and aggrivated I decided to bite the bullet and buy new RottenDog CPU and I/O boards (because it might have been an IO issue all along). I figured I could sell off the original I/O and Whitestar board here n pinside to make up some of the difference - fully explaining in the sale what happened to the orginal boards.
So, I got the new Rottendog Boards in the mail from Pinball life - they came pretty quick. I updated the chips from 3.0 from the original board to 5.0 and moved over the other chips that are the same from 3.0 to 5.0. ... and installed both new boards.
The game started up right away and I THOUGHT I was out of the woods. Then I tried to play a game - and the RIGHT FLIPPER wouldn't respond / work. Everything else worked perfectly - just the RIGHT FLIPPER. So I checked cleaned the contact for the flipper. Still didn't work.
So, I opened the service menu and had it run a cycle of all coils - and the right and left flipper worked fine.
I then pressed the service/ credit button inside the coin door and not only did it fire the flipper - but it added a coin as well. Kind of hard to play pinball using the left flipper and then a button inside the coin door for the right flipper?!?!??!?!?! LOL!
I checked all the wiring harness from the flipper button all the way up to the boards and there are no hacks, crosses, or repairs.
So everything works - but the button for the flipper doesn't - unless you press the CREDIT button inside the coin door.
I am completely at a loss now and frustarted beyond belief that I am have SO much trouble with this ONE table / pinball even after replacing ALL the electronics in the backbox - due to ignorance and further frustration.
So - I ask - NOW what should I be looking for to remedy this. Where does the contacts for the flipper button (not the coil) connect in the backbox to make the coil fire?
BTW: I checked all the connectors, all the pins, all the rom legs to make sure they are seated properly and everything looks fine.
Please advise. And thank you in advance for any assistance offered.
Once I get this working (hopefully) - I will post the previous CPU and I/O and plasma DMD up on the for sale section at a low price if anyone is interested.
