The GI lights work just fine. In fact, everything works great except the feature lights. Was working just fine until I broke it down to move it.
Checked all fuses, checked connectors, I'm lost on this one.
Quoted from Brewchap:Yes sir
Then I'd check power leaving the board. Try and isolate board issue, or something wrong out in the game.
Quoted from Brewchap:Was working just fine until I broke it down to move it.
Any chance you missed a connector, or got one on wrong or in the wrong spot ? I'd go over your work carefully. Easy to miss something.
I’m not familiar with early ss Ballys, but some early ss pins have a fuse under the playfield that controls playfield lights
Connectors are all correct, double checking with the key plugs also.
The fuse under the playfield for this pin is for the solenoid.
Quoted from LTG:Then I'd check power leaving the board. Try and isolate board issue, or something wrong out in the game.
Best to start with the rectifier board I guess.
I found J1 pin 7 of the rectifier board was broken. after repining, the lights came back on. Thanks guys for helping out with the suggestions. It pushed me to the right area for repair.
This page was printed from https://pinside.com/pinball/forum/topic/playboy-lost-all-playfield-feature-lights and we tried optimising it for printing. Some page elements may have been deliberately hidden.
