(Topic ID: 269834)
Playboy drop target coil locked on
By SoCalPinballs
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by BigAl56
#1 3 years ago
I just finished restoring a Bally playboy pinball machine. I installed a new CPR play field. The game was working 100% before I did the swap but now when I go to power the game on the drop target coil locks on. I can’t find any problem with the wiring. Any help would be appreciated.
#2 3 years ago
What transistor drives that coil? Is that transistor functional?
#3 3 years ago
I pulled the driver board out of a working KISS and it did the same thing.
7 months later
#5 3 years ago
Coil activation is fairly simple. The banded diode side of the coil get's 43v and a transistor sends a ground to the other side.
To troubleshoot, turn the power off and make sure the solid yellow wire is soldered to the diode band side of the coil.
Unplug J5 from the SD board. Power up, does the coil lock on? if yes you have a ground short in the activation wire. If not you have a board problem.
Also make sure the 1A SB fuse by the flippers is just that. It should blow to protect the transistor from a locked on coil.
San Diego, CA
Coffs Harbour, NS
$ 69.00
5,000
Nashville, TENNESSEE
$ 10.95
2,900 (Firm)
Macomb, MI
$ 18.95
Third Coast Pinball
Retro Electro Designs
$ 12.00
This page was printed from https://pinside.com/pinball/forum/topic/playboy-drop-target-coil-locked-on and we tried optimising it for printing. Some page elements may have been deliberately hidden.
