(Topic ID: 242790)
Playboy coil Help. Resolved
By tatman9999
1 year ago
  • 24 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Lovef2k
There have been 13 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
I have a non working 1978 playboy. I replaced MPU , led, , solenoid board with new Alltek. I replaced power driver board. I have 6 coils not working 3 pop coils, drop target coil and both slings. They all have 43v . All switches are working. Any ideas what I can checks. I also put new connectors on power board. The flippers coils work and the side hole coil works.
#2 1 year ago
Is the right slingshot switch incorrectly activating the knocker in game?
Is the grotto kickback coil working?
By "side hole coil" do you mean outhole?
#3 1 year ago
Quoted from Quench:
There is a knocker. Not sure what you mean on right flipper switch?
#4 1 year ago
Quoted from Quench:
The grotto hole is working. The flippers are working, the ball eject is working. The 3 pop bumpers , the coil for drop targets and both slings are not working.
#5 1 year ago
Quoted from tatman9999:
I said right "slingshot" switch, not "flipper"
The fault you are describing partly says that one of the signals used to select which solenoid to activate is shorted to ground and if that was the case, when you play a game and activate the right slingshot switch, the knocker coil would activate instead of the slingshot coil.
When you go to solenoid test mode (press the little red button inside the coin door 3 times) do any coils activate at the wrong time with respect to the solenoid ID table for test mode in the manual?
#6 1 year ago
When I go to test the only coils that activate are the coil that puts the ball in to the shooter lane,both flippers,and the Grotto coil. When the other coils that don’t work are supposed to activate I see a red light on Alltek board flash but no coil. All switches are working. Also knocker is not working in test.
#7 1 year ago
If you have not done any work on the plugs I would unplug and replug A3J5 a couple times and see if that changes anything. Start with the simple stuff. Sometimes its just the connector.
If you see no change, unplug the coin door and see if that makes a difference. Easy checks. Sometimes its a short in the coin door.
Shawn
#8 1 year ago
Do you measure 43 volts DC on the yellow power wire connected to the slingshot and pop bumper coils?
Does the knocker activate - is it connected or has it been removed? (it's in the cabinet lower right hand side) - details of the knocker are important because it might help point to a logic problem.
#9 1 year ago
Did you replace the MPU with an Alltek or just the LED on the original MPU? If the corresponding LED on the SBD is lighting up then I would think you have a connection issue. Since this game wasn't working when you got it, you don't know what other people have done to it and believe some people that shouldn't work on pins do and screw them up. Try following the wires from coil to coil. Look for bad solder connections on the coil lugs. Check for continuity on the common side of the coil to the other coils. Make sure none of the coils were wired backwards. This could break the flow of the daisy chain of the coil wiring.
The flippers are on a separate circuit and only work when the flipper relay is active(closed) and of course when the flipper buttons are pressed.
#10 1 year ago
Quoted from Quench:
I have 43volts on yellow and the other wire also. Know doesn’t activate. Knock also has 43 volts.
#11 1 year ago
Quoted from Lovef2k:
Yes I replaced all boards with Alltek. I checked all connections at coils.
#12 1 year ago
Quoted from Mk1Mod0:
Shawn
I tried with coin door unplugged and same thing.
#13 1 year ago
Also on the driver board. The red leds at the solenoid diagnostic leds . When I push 2 of the pop bumper switches a red led lights up the other pop switch doesn’t light a red led and both slings don’t light it ether.
#14 1 year ago
Also in test the grotto goes on 2 times in a row.
#15 1 year ago
At what solenoid test numbers does the Grotto activate?
If you can go to solenoid test mode and note down exactly which LED (or none) on the solenoid driver board blinks at each solenoid test number then we can map out what's going wrong. Having said that the issue is likely just connector related with the solenoid select signals at either J4 on the solenoid driver board or J4 at the MPU board. And to be honest you likely have two signals with bad connections. The LED to solenoid number list should expose which signals are having problems.
#16 1 year ago
Quoted from Quench:
Q8 actives 2 times and grotto coil is activated both times.
And Q16 flashes 2 times with no coil working.
No other leds flash during this test.
#17 1 year ago
At which solenoid test numbers does it happen?
Again, which solenoid tests does it happen?
Please be very specific with the details. You are our eyes to this problem and I can't map what's going wrong otherwise.
#18 1 year ago
Quoted from Quench:
How do I know what number it is on? Thanks for all the help.
#19 1 year ago
Quoted from Quench:
Thanks for all your help. I repinned j4 on MPU and driver and all is working. Now I need to find a backglass. I put the New CPR in there and it is dark and not as good as the original. Did a restore new playfield, new plastics, stencil the cabinet and clear coated it. Not happy with CPR backglass
#20 1 year ago
Original and cpr pics
ACC3482F-4C39-4F1F-A4B6-DF470DBA0377 (resized).jpegF634DBE4-8BCE-4B22-94CF-12D818AC759C (resized).jpeg
#21 1 year ago
Wow, she's a beauty! Glad you got it going.
BTW, to get to the game test modes you press the little red button inside the coin door.
First press starts the feature lamp test
Second press runs the display test
Third press runs the solenoid test
Fourth press runs the sound test
Fifth test runs the switch test
Sixth to eleventh presses goes through score level awards and game audits
It's listed in the manual
#22 1 year ago
Quoted from Quench:
Thanks I just did a playfield swap, I stenciled the cabinet and clear coated it.
2EA159B7-9011-416C-97E4-D692710B4F4B (resized).jpeg41FA56C3-C24A-4A3E-8147-11362529D69F (resized).jpeg46F70AAA-04A4-43F6-B09C-114039F45DF7 (resized).jpeg478DA310-22AE-4810-8FE2-5338BF6AE79B (resized).jpeg9FACE2E5-EB12-455A-9804-3F76B1B58981 (resized).jpegC4C7E9D5-CB63-41D4-BD4B-660C6F6DA07C (resized).jpegD820E781-5C49-4EA6-9BF5-A8CB0DE7A4E4 (resized).jpegF8AAE4C2-1EF6-4134-9DA9-4ED2AC8CA7C2 (resized).jpeg
#23 1 year ago
Problem was fixed with replacing j4 connectors on both MPU and solenoid board.
#24 1 year ago
Nice job on the repaint!
$ 11.00
Third Coast Pinball
Displays
PinballSolutions.eu
$ 9.00
Mankato, MN
