Plastics are loose - Acorn Nut is Bottomed Out
(Topic ID: 228833)
By Skidave
4 months ago
  • 43 posts
  • 14 Pinsiders participating
  • Latest reply 4 months ago by wayout440
There have been 11 images uploaded to this topic. (View topic image gallery).
#1 4 months ago
I'm working on my first SS state machine and I'm not used to the posts and acorn nuts.
I received the machine with what looks like new acorn nuts, but they are bottomed out on the post and the plastics are loose. What am I missing? Is there a spacer missing or are these the wrong acorn nuts? Or, should they be loose fitting?
#2 4 months ago
The hole is probably too big
#3 4 months ago
Is every one like that or just that one? It's possible they just got two posts swapped. Is that one behind the drop bank in the pic taller?
#4 4 months ago
I have same problem, I would recommend using some type of white plastic washer(s) beneath the acorn nut cover to take up the "slack". I'm looking in my hardware store tonight, see if I find anything.
Over the years, post sizes, types, etc get all screwed-up when machine has been worked on those many years in the past...........
#5 4 months ago
I get rid of the cheap looking plastic acorn nuts, and add 2 washers one on top and one under plastic, and chrome arcon nuts, looks so much better!
#6 4 months ago
I just swapped them out for new lock nuts on my Comet with washers also on most. If i could washers on both sides of the plastic if it would fit.
Probably not the most favorable option but i just don't like the look of them.
I was thinking about getting Colored Acorns or the colored ionized colored lock nuts just for a little color.
#7 4 months ago
Quoted from wdennie:
Quoted from BertoDRINK1:
Disagree. Comet gets white nylon acorn nuts...at least, that's what is on the flyer. They look great when you replace them with brand new. Add PETG clear fender washers under the plastics.
#8 4 months ago
Plastics should be loose anyway
#9 4 months ago
Quoted from tandem2:
I agree here. I always use rubber nubbins on mine so that they have some give. Usually the rubber will fly off instead of a chunk of plastic. If I use nuts I always leave them a bit loose
I was thinking about getting Colored Acorns or the colored ionized colored lock nuts just for a little color.[quoted image]
Confused, why the washers?
#10 4 months ago
Quoted from zacaj:
"Crystal clear protective washers are made of PETG plastic, a nearly undestructible high impact type of plastic, much more durable than acrylic
Clear polycarbonate fender washer for protection of slingshot posts and other high ball impact areas"
#11 4 months ago
Quoted from wayout440:
I understand the large clear ones. Wondering about the small metal ones.
#12 4 months ago
Quoted from zacaj:
Probably shouldn't be there - perhaps someone added them.
The OPs game is Supersonic, so the correct cap to use should be these white rubber post caps
#13 4 months ago
Quoted from wayout440:Probably shouldn't be there - perhaps someone added them.
#14 4 months ago
I've noticed acorn nuts for vintage Bally games are different for Stern games of that era. The ones that fit a Bally are a different thread. Not a fan of the rubber ones.
#15 4 months ago
Quoted from pinkid:
Interesting fact. Most parts are very similar for this era.
#16 4 months ago
Quoted from pinkid:
And lets not forget Gottlieb's metal acorn nuts and non-threaded post screws :/
#17 4 months ago
Guys,
Thank you for the replies. Yes, this is a Supersonic. I don't like how loose the plastics are. Wayout440, do you have a source for the washers you use? I have a kit of white and opaque nylon washers with different thicknesses. I was planning on spacing washers in there, but leaving the plastics loose (but not flopping around as they do now).
I'm not restoring. I would like it to look original, but with some of my preferences.
Where do you get the white rubber push on caps?
#18 4 months ago
Marco Specialties and Pinballlife carry both items, and probably other pinball parts distributors as well.
#19 4 months ago
God acorns are the worst. Firs thing I do is throw them away and replace with Post caps (Chesterfields).
https://www.pinballlife.com/white-post-caps.html
#20 4 months ago
If you need clear PTEG fender washers I have them for sale, 35 cents each and only $3.50 shipping in the lower 48.
#21 4 months ago
Dave, Bally has 2 different length posts. The one on the right in your post is the wrong length, hence the loose plastic. The short posts are 1", longer are 1-3/16". I usually swap out the longer ones under plastics to the shorter length to avoid the screw head scratching the plastic. The white nylon acorn nuts are what was OE for Supersonic but the rubber nuts are easier to remove during the enviable switch adjustments under slings and other PF work. The OE nylon nuts are easily stripped out from over tightening so if that's your choice do not over torque them. Also the old nylon nuts will clean up nicely if soaked in bleach for a week, will look nearly new. If you prefer the rubber style, PBR has the best price on them.
#22 4 months ago
And yes, the nylon post nuts are correct for Supersonic.
#23 4 months ago
Quoted from tomdrum:
Those are rubber post caps in the flyer pic.
Here is another link to a discussion thread. I am in the belief that the flyers *possibly* do not always match production games, and both were used around the years of this Bally era. My 1981 Bally Elektra had the rubber caps...and regardless of keeping a game original, eventually you end up finding these critters down in your outhole
https://pinside.com/pinball/forum/topic/nylon-acorns-postnuts-vs-rubber-nuts
#24 4 months ago
Ok, so it looks like we're sorting out the fact that the caps on there now are not what was originally on there.
I went to hardware store last night, looked around for some type of spacer.
Here's what I found:
I purchased a 3/4" length of white nylon(?) tubing from plumbing aisle. The tubing slips over the space left between my post and the post cap, removing the extreme amount of play on the plastic. I've got enough tubing for 1,000 games as you only use a tiny bit!!! Cost about $4.
Not "stock" but just though I'd throw this idea into the mix. You can always dye the tubing also if you are using colored caps, but you don't really see the tubing that much.
So plastic are *supposed* to have some play in them? This helps them absorb impact better without breaking - hmmm, makes sense, although I could see some rubbing on the underside of the plastic as a result unless you put some mylar down on it.
#25 4 months ago
Quoted from Pinball_Nate:
That's where the plastic washers or full plastic protectors could be a solution. I've always thought the protectors or washers would go under the plastics, because that is where the art is printed. This is just my opinion, as I generally keep my games original and don't go out of my way to add all these extras.
#26 4 months ago
I'm still going with its the wrong post.
#27 4 months ago
Thanks guys. Each step on this machine uncovers some previous work that was not correct. I see PBR has the correct size and color posts for this game. I'm just ordering new and putting it back to the way it should be.
I'll adjust the acorn nuts to secure the plastic, but leave some room for the plastic to move.
#28 4 months ago
Yes, they would.
I actually made my own protectors for the infamous center plastic in Taxi out of heavy plastic, and it seems to be doing the job. May do this for my Meteor project also.
#29 4 months ago
Those rubber barrel post caps will pop off on a direct strike, saving the plastic from being destroyed.
Remember to install those clear plastic fender washers correctly.
They go UNDER the post nut.
That leaves a safety gap to absorb any strikes, rather than transfer that energy to the expensive plastic above it.
#30 4 months ago
Yes, they would.
On my ex-Taxi after that plastic broke a 2nd time, I just left the cracked center plastic in place and installed the replacement on top of it. That one sure takes a beating!
#31 4 months ago
Quoted from vid1900:
Until, of course, the plastic is now off and wedged in the slingshot mechanism.
#32 4 months ago
Quoted from o-din:
It can happen.
Your wife will just keep playing, laughing manically as the plastic is destroyed.
#40 4 months ago
I have to respectably disagree. I have bought 2 dozen early SS Bally project games, many in the early 2000's which were from operators warehouses that still had the OE #44 brass base bulbs under the plastics and PF. Supersonic was a March 1979 release. While I've haven't owned one, I have bought a Star Trek 4-79 release, 3 Paragon's 6-79 release, 4 Silverball Mania's 2-80 release and a Space Invaders from 4-80. All had the nylon post caps. 1st game that I encountered that had rubber post caps was Xenon (11-1980). I know I'm splitting hairs but I believe the nylon post caps were installed into 1980.
#41 4 months ago
hmmmm. you left out 1979 Future Spa and 1979 Dolly Parton
#42 4 months ago
My Bally KISS had the rubber caps. I think they were factory.
#43 4 months ago
Quoted from pinkid:
A lot of KISS had the rubber caps, but you'll see the nylon caps on a lot of them as well. It also looks like nylon caps on the flyer. I'm going to go with 1979 as a transitional year. I don't think you'll see many, or any 1978 and earlier with the rubber posts factory. Anyway, it's really not all that important. We can always install what we like .
$ 45.00
$ 50.00
$ 22.00
Yorktown Parts and Equip
£ 39.00
PinballToys
$ 24.25
The MOD Couple
$ 369.00
$ 209.99
PinballBulbs
$ 66.95
$ 49.99
$ 89.99
