(Topic ID: 306757)
Pitch & Bat magnet coil ?
By dr_nybble
2 years ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 2 years ago by dr_nybble
    #1 2 years ago
    Anyone know if coils like this are available? Nominally a S-24-850 but it seems to have a possibly (now burned up) fish paper core and a metal insert that provides the slider/curve feature. I think these coils are still good resistance-wise but they are kind of falling apart / burned.
    The diameter of the metal insert is 0.710". I measured the inside diameter of a S-24-750 coil I got from pinball resource that has a plastic core and it is 0.705".
    Apart from the metal insert, there is nothing in the coil except the wire.
    #2 2 years ago
    the new coil you got from Steve probably has a plastic coil sleeve . metal sleeves are no longer used.
    I had a friends pinball machine where the sleeve was removed at some point in its past & it wore through and falling apart
    are you saying the plunger doesn't fit in the new coil sleeve ? ... or is that a plunger at all ? I wonder if it's supposed to go in without a sleeve & induces a magnetic field in the path of the ball
    #3 2 years ago
    It’s a solid piece of metal that acts as a magnet to divert the ball. The flat part at the bottom sits directly against the bottom of the playfield in a routed recess. The diameter of the opening of the new coil is too small. I bought two NOS coils from John’s Jukes.
    This page was printed from https://pinside.com/pinball/forum/topic/pitch-amp-bat-magnet-coil- and we tried optimising it for printing. Some page elements may have been deliberately hidden.
