I was working on a Stern MPU with the LED locked on. On PinWiki it says
“Ensure that there's not simply a problem with Q2 or the LED itself (i.e. the board isn't actually booting up anyway, just with the LED locked on). A logic probe on pin 18 of the U11 6821 PIA will tell you if the LED signal is changing.”
I put a logic probe on pin 18 of the U11. The probe showed LOW – No pulse. To me, that shows the signal is not changing.
Then I checked a working MPU and got the same reading, LOW – No pulse.
What should the logic probe be showing on pin 18?
Bob
