UPDATE: Pleased to announce the Pinball Life and Flipper Fidelity have both addded the PinVol control to their list of fine products. Pick up a PinVol with your next order from them. You can also still get them directly from me.
What is it? This is a very neat external volume control switch for late-model Stern pinball games. No getting the key, opening the coin door (which shuts down the flippers) during game play to adjust the volume. Just reach over and hit the convienant rocker switch.
It is a MUST for games like AC/DC!!!
The control fits in the cabinet "tournament" button hole directly below the start button. The switch itself is single clean up/down rocker: push it up to increase the volume, push it down to lower the volume.
Installation is 100% plug and play: Remove the existing blank plug, put the new harness in and fasten the nut. Run the wires along the others to the coin door. Unplug the cable going to the existing coin door switch bank, and plug in the new switch harness. That's it!
Construction is all high quality, using correct OEM Molex crimped connectors and sockets. Nice part is that the switch is fully recessed in the opening. The price from me direct is $30/each + $5 shipping via USPS First Class Mail, or get them at Pinball Life or Flipper Fidelity.
The switch will fit any Stern with the cabinet mounted tournement opening, and also has a connector for the four position switch on the coin door. For sure everything from Ironman up, perhaps others. Photos below.
Thanks.
Post edited by ddalski : Where to Get Pinvol
