(Topic ID: 234224)
Pinsound+ mix install problems
By Jimmyhonda
5 months ago
  • 79 posts
  • 7 Pinsiders participating
  • Latest reply 4 months ago by Rdoyle1978
    There have been 11 images uploaded to this topic. (View topic image gallery).
    There are 79 posts in this topic. You are on page 2 of 2.
    #51 5 months ago
    I go to volume zero to switch mixes, correct?
    #52 5 months ago
    I'm beginning to wonder if the whitestar system works differently. I cannot find documentation on multiple orchestrations, and it wants you to copy the zip file directly to the USB and let it do the work. Is this the way you originally did it?
    #53 5 months ago
    Even so, the diag file said it was active, so I think my setup is correct.
    #54 5 months ago
    Yes, I used the Pinsound program to pull the files to the usb. I’d like to stick to one mix for now. Just in case. Hawknole.
    #55 5 months ago
    Should I try now?
    #56 5 months ago
    Should I test it now?
    #57 5 months ago
    It will read the first folder by default.
    Okay, please try again. The USB drive is setup correctly. At this point, the hardware is beyond what I could help, but I would suggest disconnected everything and doing it again paying detailed attention to all cable connections, orientation, etc. Not saying you haven't done so already, but at this point is all correct you will need to engage the bros and PinSound. They are very helpful, but can be slow sometimes.
    #58 5 months ago
    Just wanted to shout out to Mr T for all the Pinsound help he’s provided. I know there’s a bunch of us who have been helped by his threads/PMs/posts with the Pinsound board. Cheers!
    #59 5 months ago
    Thanks mr T! I’ll let you know. Much appreciated.
    #60 5 months ago
    IT WORKED!!! You are the man Mr T!! Thank you my friend!!
    #61 5 months ago
    Awesome, glad to know we got to the resolution. Bottom line is that the directory structure was all incorrect. I think the final straw was removing that pinsound.config file from the audio folder at the same level where the orchestration folders existing (there should be a pinsound.config file inside each of those folders.).
    #62 5 months ago
    #63 5 months ago
    Well done, man. I love seeing stuff like this.
    #64 4 months ago
    Im having the same problem with my pinsound+ on data east hook
    #65 4 months ago
    Quoted from garretswinning:
    Can you please define/elaborate upon your exact issue?
    Also, screen shots of every level of your USB folder structure would be helping starting from the root down to where you see music/jingle/Sox/etc. folders.
    Finally, drill down to a sound file and tell me what format it is (oog or wav).
    Just want to address some common format issues.
    #66 4 months ago
    I installed the pinsound+ 100% properly wired. Had a friend clear the flash drive and re installed sound file from pinsound. Plugged in the drive to the board. I listened the whole time and said the download was complete. Now that its good to go i get no start up sounds or anything and just get the crock clock sound and takes about a minute for it to stop and end with no sound. I am running chads 5.1 code along with the dmd chip as well. Could this be where my issue is?
    #67 4 months ago
    Plug your usb drive into computer and please provide the screenshots I requested. Also respond to my question about file format. Sorry, but cannot make assumptions. This info should be enough for us to determine if a format issue or if some other problem.
    #68 4 months ago
    Mr_Tantrum
    20190210_114712 (resized).jpg20190210_114725 (resized).jpg20190210_114800 (resized).jpg20190210_114846 (resized).jpg
    #69 4 months ago
    Quoted from Mr_Tantrum:
    They are wav files
    #70 4 months ago
    Mr_Tantrum
    Looks like the structure is ok. Is it common to have only 4 sub folders for D/E games? Do the WAV files play when you double click on them in the computer ?
    #71 4 months ago
    Yes, the structure does look correct.
    Couple of things now:
    1) What color is the PinSound+ Status LED after boot (i.e. when the game PinSound+ should be working)?
    2) Please run a self-diagnoses to see what info the logfile produces.
    - Go to this link https://www.pinsound.org/help/pinsound-studio
    - Scroll down to the Record and replay section (silhouette with headphones) and under Recording click the "config.ini" link and save the zip file to your computer
    - Unzip the config.ini file and edit it | set psrec = false and set debug = true
    - Save file then copy it to the root of your usb drive
    - Insert USB drive, turn on pin, and wait until it fully loads (i.e. the point at which it should be playing sound)
    - Turn off pin, put drive back in computer, open the pinsound-self-diagnosis.txt file, copy contents, then post to this forum.
    #72 4 months ago
    The status led is green. The daughter board is flashing blue. Have inserted the usb back into hook. All that was said from the sound was there are no sound files on the usb flash drive.
    #73 4 months ago
    What do you mean no sound files? Did you delete them (didn't need to)? Just needed you to put config.ini file in root as described, run PinSound, then put back in computer and edit the file to see what it logged, copy that log, then paste here in the forum so we can read it.
    #74 4 months ago
    If status led is solid green that means the board is ready (good sign).
    #75 4 months ago
    Must of made a mistake. Gonna redo evertything said this evening. Will post with the results. Thanks again for the help.
    #76 4 months ago
    I may have time for a webinar this evening if that would help. PM me when you are ready. Main thing is I want to capture the logfile from the PinSound to see if it tells us anything (it may or may not). Unfortunately, you have to do some manual steps to enable the log capture.
    #77 4 months ago
    #78 4 months ago
    Just updated the firmware and still at the same point.
    #79 4 months ago
    Why do you keep switching USB drives? Did you use a different one for the firmware?
    Medisinyl Mods
    $ 48.00
    $ 14.00
    Yorktown Parts and Equip
    Metal-Mods
    $ 189.00
    Displays
    Boston Pinball Company
    £ 29.00
    PinballToys
    $ 2,000.00
    Great American Pinball
    $ 6,995.00
    Flip N Out Pinball
    $ 46.95
    PCB Emporium
    $ 625.00
    $ 7.65
    Cabinet Parts
    Third Coast Pinball
    $ 24.00
    $ 29.99
    $ 8,999.00
    Little Shop Of Games
    € 6.50
    Buthamburg
    $ 10.50
    The MOD Couple
    $ 86.95
    $ 1,099.00
    $ 76.95
    $ 999.00
