Is there a remix for no good gofers? Maybe different main song and gofer voice?
Anyone know where I can get the original card? Seems like only plus version for sale and it's 370. Looking for standard
Used is fine
Quoted from delt31:Anyone know where I can get the original card? Seems like only plus version for sale and it's 370. Looking for standard
Used is fine
It seems they’ve discontinued the old board. Look at K’s Arcade and PPS/BAA. They may have some old stock, but I highly doubt it will be discounted. Hopefully, though! Keep looking - every once in a LONG while one will come up for sale here.
Just posted my latest (9th) Getaway PinSound orchestration to the community (awaiting approval before it is available for download). All instrumental cover songs on this one.
http://pinsound-community.org/forum/index.php?/files/category/22-getaway
Interesting problem that someone may know the answer to. I’ve been having trouble with my pinsound on CFTBL. Wasn’t playing despite everything seemingly installed correctly - then suddenly last night - worked perfectly with the Wool Mix and sounded great - small issue - no flippers! Nothing registered on switch test or flipper test. Pulled and checked all the fuses and all were fine. Turned the game back on - flipper back, but now no sound again! Any ideas?
Quoted from dendoc:Interesting problem that someone may know the answer to. I’ve been having trouble with my pinsound on CFTBL. Wasn’t playing despite everything seemingly installed correctly - then suddenly last night - worked perfectly with the Wool Mix and sounded great - small issue - no flippers! Nothing registered on switch test or flipper test. Pulled and checked all the fuses and all were fine. Turned the game back on - flipper back, but now no sound again! Any ideas?
Power supply stressed by pinsound? Sounds similar to some issues with ij and pinsound.
CFTBL has a lot of load on it already, there's almost no headroom for mods on that game. Yank the hologram motors and bulb and see if you get any different result. Those put a big spike on the game and since they are on/off the whole time you'll get unpredictable results as far as power. What other mods do you have?
Hey how do people typically set up custom mixes (I.e. Full re-orchestrations of music, sfx And voices) for Pinsound mixes? I've been trying to get someone to make a Judge Dredd custom mix. I've done one on my own (music only) but I don't have the capability to record new voices or sfx.
Has anyone figured out if these work with older data East? Like revision 2 stuff like Robocop, Phantom, Monday night football, and Playboy 35?
Quoted from JediPimp:Hey how do people typically set up custom mixes (I.e. Full re-orchestrations of music, sfx And voices) for Pinsound mixes? I've been trying to get someone to make a Judge Dredd custom mix. I've done one on my own (music only) but I don't have the capability to record new voices or sfx.
I'm confused by your question since it seems like you already know the answer. They do it the same way you have done your music tracks, and with custom voice & sfx. The ones I have changed used either professional voice actors and/or recordings I clipped from internet sources.
Quoted from Mr_Tantrum:I'm confused by your question since it seems like you already know the answer. They do it the same way you have done your music tracks, and with custom voice & sfx. The ones I have changed used either professional voice actors and/or recordings I clipped from internet sources.
That's the correct answer. Do some research about Digital Audio workstation (DAW) software, like Reaper or Audacity (I hate Audacity, but it's free). Reaper is $30 for a student license.
Yes. Audacity and YouTube. Youtube for sfx/Spotify for music. I use cubase for creating more extensive sound effects and voices, but if you find FX that sound great on YouTube that's a very easy route to go. In audacity you select your soundcard as source (loopback), hit record in audacity and go over to YouTube and hit play on the audio clip you want to record. Stop the recording, edit start and end position with short fade in/out, do some equalisation and maybe a bit compression and normalizing to get the level you want. Maybe some reverb or delay for a more exciting sound. Export as .wave file 16bit/44.1 to the folder containing the file you need to replace. Delete the old one or just overwrite it. Once you do this enough times, it gets easier and takes less time. But still it takes a a LOT of time getting it just the way you want it...
Hey everyone,
I just installed Pinsound Speakers and not sure if this happened to anyone else but the speakers sound quite quiet and muddy. It was actually much crisper and louder with my DCS speakers! I'm using Pinsound Speakers (Williams Kit) and Pinsound 1 Board with Stereo 2.1 cables on my WPC-DCS Judge Dredd. Any advice? The subwoofer itself is realllllly quiet. Sound like they are far away and travelling through packing material
I've even dialed in the recommended DCS EQ settings on the potentiometers on the Board. Ive tried three sound mixes and they all sound muddy and so very quiet.
I've contacted Pinsound and am awaiting a response.
Quoted from JediPimp:Hey everyone,
I am pretty sure you have connected it wrong. Use the CN4 Data East stereo output. And make sure it's connected the right side up.
Quoted from Hazzard:I am pretty sure you have connected it wrong. Use the CN4 Data East stereo output. And make sure it's connected the right side up.
Hi Hazzard, yes I have connected it right to the 2.1 stereo output (My Pinsound 1 board calls it the stereo 2.1 speakers output and the CN4 Data East stereo output) and due to the pin configuration there is only one way of installing it correctly.
I'll try unplugging it and plugging it in again.
Cheers,
Quoted from jboner1058:Has anyone figured out if these work with older data East? Like revision 2 stuff like Robocop, Phantom, Monday night football, and Playboy 35?
The older boards won’t work, but I spoke with Pinsound at TPF and these will definitely be supported by the new board at some point.
Quoted from Rdoyle1978:CFTBL has a lot of load on it already, there's almost no headroom for mods on that game. Yank the hologram motors and bulb and see if you get any different result. Those put a big spike on the game and since they are on/off the whole time you'll get unpredictable results as far as power. What other mods do you have?
Turns out it was my ribbon cable. I switched it over from another Williams machine and all worked well. This may be the problem JediPimp is having as well. Thanks for the help. Sounds so good now with the new mix and speaker upgrade.
Quoted from dendoc:Turns out it was my ribbon cable. I switched it over from another Williams machine and all worked well. This may be the problem JediPimp is having as well. Thanks for the help. Sounds so good now with the new mix and speaker upgrade.
even better! great job figuring that out
I asked Pinsound for a replacement Subwoofer (which they gave me) and everything is sounding perfect now! The Pinsound guys are top notch when it comes to customer service. My cabinet vibrates a bit from the subwoofer now!!!!!
Quoted from Hashman:I just put a pinsound board in my Indy 500. Updated the firmware as well. Problem is that wrong sounds play and wrong timing of music all the time. Any ideas?
This issue is now fixed. I reported it to pinsound and they fixed the issue
Quoted from ajnin:This issue is now fixed. I reported it to pinsound and they fixed the issue
How did they fix it? Firmware update?
I had one of the earlier boards, I decided to just pull it out of the machine. The boot up time really bothered me, I don't know if the newer boards are the same. Running custom high quality is nice, but I doubt I will put this board back in any of my machines.
Quoted from Goalie:I had one of the earlier boards, I decided to just pull it out of the machine. The boot up time really bothered me, I don't know if the newer boards are the same. Running custom high quality is nice, but I doubt I will put this board back in any of my machines.
The 12-second or so boot time is a deal-breaker?
Yeah it’s annoying to have to wait a few seconds, but if you get a high speed usb drive it cuts it WAY down
Quoted from Blackjacker:The 12-second or so boot time is a deal-breaker?
To each his own I guess. Mine play the THX intro music and shake the house during their boot sequence; it's an epic experience just turning the Pinsound games on let alone playing them!
Quoted from FlippyD:To each his own I guess. Mine play the THX intro music and shake the house during their boot sequence; it's an epic experience just turning the Pinsound games on let alone playing them!
Wha what? You can have an intro sound instead of the blip, blip, blip, blip?
Quoted from Damonator:Wha what? You can have an intro sound instead of the blip, blip, blip, blip?
if you copy your own “boot.wav” sound file in your “audio” folder, the PinSound board will play this file instead of the standard startup sound.
New boards have also a boot up time. Don’t think this has changed much but never timed it. However, just to skip this product because of a 12 sec boot time ??? You must be the most impatient person I know. You can already start playing if you wish.
I’m no audiophile, so the benefits of the board were a bit lost on me, i never saw much content available either unless you have a few particular machines, and yeah the bootup time is anoying to me, so out it goes.
You still get some of the beeps, but on my Getaway I have the sound of a Lambo Diablo starting, revving, peeling out, and then accelerating off into the distance.
Quoted from Goalie:I’m no audiophile, so the benefits of the board were a bit lost on me, i never saw much content available either unless you have a few particular machines, and yeah the bootup time is anoying to me, so out it goes.
On the 90's pins you don't have to be an audiophile to appreciate true stereo CD quality sound versus mono low bit depth midi. If you couldn't tell the difference then my assumption is that you didn't have a quality custom orchestration to compare to the original. If anyone expects to do a one for one replacement of their sound card with a PinSound and it magically make a sound difference, you are sadly mistaken. To begin with, you will need a custom orchestration with new music/sounds, possibly rewire your speakers for stereo, and potentially replace you speakers with ones with better frequency range and bass. When you do it right, it is night and day and can never go back to the original sound.
I just installed the latest firmware and it seems way faster to me. It used to bother me but it does not take any longer than my swle to boot. Its a great mod. Support is excellent also.
Quoted from TimberOne:Nice!!! I dont have the mixing software installed, but you just add the file?
You just have to add a file called boot.wav and put it into the audio folder on the usb stick. Boot.wav can have whatever audio you want in it. A program like Audacity can help you make one if you don't know where to start.
oops, beat me to it !
Quoted from alveolus:Any update on a SAM version?
Hope they PinSound Guys can figure out how they get the Pinsoundboard working with the SAM-System.
Well, got it to work but not what I expected. It still does the chirp, chirp, chirp... I thought the boot file replaced that sound.
Quoted from TimberOne:Well, got it to work but not what I expected. It still does the chirp, chirp, chirp... I thought the boot file replaced that sound.
No, just the final sound when it is complete.
Quoted from fuseholder:I have one in my CFTBL. The boot up time has never been a issue for me. The quality of the sound is phenomenally better.
Thewool mix, right? That is a great one
Quoted from docquest:if you copy your own “boot.wav” sound file in your “audio” folder, the PinSound board will play this file instead of the standard startup sound.
So you could also just create a silent wav file of 15 sec. to have it silent.
Quoted from PeterG:So you could also just create a silent wav file of 15 sec. to have it silent.
No, the "chirp" is letting you know the board is booting and I think checking for new audio files etc. Once the board boots it plays "boot.wav".
If it takes longer than 30 seconds, check your power supply board. My LW3 got slower and slower after the pinsound install, but hten I realized the DMD wasn't turning on either and the whole system was slow. New PSU board fixed that.
Quoted from MightyGrave:Hope they PinSound Guys can figure out how they get the Pinsoundboard working with the SAM-System.
I hesitate to say never but it will be a trick. There is no soundboard on the SAM system. There is a digital to analog converter and some borrowed CPU, RAM and storage. The SAM sound system is pure software. There is no good way for an external board to determine when anything is being played.
SAM is moderate fidelity not high fidelity. Mono, 24 kHz and compressed 4 to 1. It sounds great for what it is. Without the cooperation of system software after the fact (which is not forthcoming) there is no way to hook into the event stream.
Sorry.
ddt
Hey David,
thank you for this information, so now the whole community know what the problem is.
And yeah we speaked about this after your Seminar in germany at Pinball universe. I'm the guy with the Dialed In Beachtowel.
Maybe we (all met owners) should do a petition (better Met Sound) to bring LFS in the boat for help.
Bought a 4 band eq and new tweeter to make the sound a bit more bearable
Quoted from fuseholder:Yes, it’s phenomenal.
Hey good to hear people are still enjoying this!
This page was printed from https://pinside.com/pinball/forum/topic/pinsound-card-reviews-anyone/page/26 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
