Lots of WPC have that issue in combination with DMD and PinSound - I use an external power supply for PinSound and Shaker Drive. DMD is connector to standard supply - no resets, no errors.
Ty for the info. So a standard arcade power supply will work? And i would have to hook the 12 v to the pinsound board?
Yes, and you should prepare more power for a possible Shaker driven by PinSound-Board. I use stabilized 12 Volt and 10 Ampere.
Here's a question for people with Pinsound in their STTNG. Does yours hesitate to play some music tracks? I notice it when starting a mode after the mission start jingle. There's a second or two delay before the track starts on mine.
AND, at the end of game, the final music track repeats forever well after the game is over. It's using the main theme track at the end so I can't just add in 10 minutes of silence to compensate for this bug.
I am new to pinsound, but am thinking about adding one to WH20 and TFTC. Are their any good reorchestrations available for these games? On youtube I could only find one for TFTC, but without Danny Elfman's theme song was huge turn off / disconnect from the theme. I heard something about the original voice actor of Wet Willy rerecording speech. Did that ever happen? That would be awesome!
Quoted from OldSchoolBlood:
Go to pinsound community forum, create an account, and then you can download any available orchestrations. From there, you will need to have someone provide you with a game recording and you can play back on your PC to get an idea of the orchestration.
I found the reason for the music not starting when it should. I had some dead air at the end of a jingle. I trimmed it and now it works like it should. Still got the odd issue with the music at game over, though.
Quoted from pinballshark:
Good catch!! I have not experienced the end music bug on any of my pins which have a PinSound board. I assume it's not a similar issue? Also check your config.txt file for any strange settings
I have a DESW and still have the issue where the pinsound does not boot half the time. From their website it says a known bug and would be fixed soon... 1 year ago. I updated my firmware, i wonder if it did not take or anyone else have this issue?
Quoted from TimberOne:
what cpu are you using?
stock or rottendog?
I went with the 20th anniversary mix, which is all new sounds from the movie. It completely changes the game in such a positive way. I absolutely love it. I did Flipper Fidelity speakers and I’m loving the upgrade. Pinsound took this game to a whole new level.
Marc
Quoted from pintechev:
Marc
FWIW pinsound is also providing upgraded speakers on their site now, less expensive than FF and a higher quality speaker. I believe it's Kevlar
Rottendog
this is why is doesn't work.
been there, done that.
I switched back to a stock cpu and NO PROBLEMS since then.
Sound board works every time.
Quoted from Rdoyle1978:
Good to know. The FF was a huge upgrade over stock and I am certainly happy. Also, stereo! It's good to know there are multiple options out there for us.
Marc
Marc
I'm not saying you'd notice the difference if you already have FF, but it is a VERY easy install, and guarantees you have properly phased speakers (one of the reasons a lot of B/W games sound so bad) and like you said.. stereo!! Plus I like being able to adjust the cab woofer and the backbox speakers independently.
Quoted from Tim_may:
Oh great, one thing fixed another one broke!
Does anyone know what happened to the multiple Doctor Who files that were on the community? There is only one left.
Quoted from waspinat0r:
So let me ask a "hypothetical" (.......) question -- let's say I have a Shadow with pinsound....is there any way for me to make the game music changed to a bunch of good stuff from the Threat Level Midnight episode of the office?
If there is an existing Shadow file for PinSound, you can modify it with any music you have. You will have to be able to edit the music to crate loop points and such, but yes, it's something you can do with a bit of work.
I've gotta say, I enjoy Pinsound, but I feel like the file conversion fails a lot, and the boot up time is excessively long.
don't do file conversion. it is a waste of time. easier to just save as wav or ogg file and drag and drop into the appropriate folder. no need to convert that way.
Quoted from awarner:
A bunch of the mixes of various games have been disappearing lately - I don't know the reason, whether it's technical or some other issue. They are around if you look elsewhere. Google PinSound doctor who mix
I always edit as wavs to save the conversion. Then religiously go an open a beer while the machine is booting up
I don't know what happened, but I have copies of them all, and installed them all. My favourite is the 70s funk version of the theme tune, just awesome
I upgraded with the stereo Pinsound speakers, and it made a huge difference again over what the board itself achieved. I'm very pleased with this excellent product, which I have in DW, TAF, STTNG and TZ. There are other machines I considered converting but didn't bother as there's only the original soundtrack on pinsound community. I'd recommend folks check out soundtrack availability before upgrading. Personally, I want at least 3 soundtracks to choose from. It really adds to the gaming experience and revitalizes and re-invents these games IMO.
The only thing that worries me is whether there's enough activity on the community to produce new soundtracks, and if the copyright nazis are having soundtracks removed (e.g. DW) that would be most worrying.
I've recently put together what I think is quite a nice Pinsound mix for Judge Dredd for my pinsound board. I've tried to post it on that pinsound community forum but my file size is too big (larger than 200MB I believe). I could put it up on google drive if anyone was interested? The voices are the same unfortunately (I don't have the talent or capacity to re-create them in HD audio) but the music and jingles are all different as is some of the FX. I have also put in multiple tracks in all of the music folders so Pinsound randomly selects a track every time (one of the cooler and less utilised features of pinsound in my opinion). The tracks range from classic punk to industrial rock to heavy rock to electronica and even some psy-trance. I went for a apocalyptic postmodern vibe. Of course the tracks are copyrighted so you would have to own the tracks yourself etc etc.
Very nice! One criticism I have about the board and it's support is that the guys don't post much information about what's going on, or how to leverage the features very well. The forums used to be better populated too; I wish we knew what the deal was. Google drive it!!
Not that I am the ultimate PinSound guru, but I have started this guide (still much to be added).
https://pinside.com/pinball/forum/topic/tantrums-guide-to-pinsound#post-3715636
Quoted from Mr_Tantrum:
Well, you kind of are...
tantrum, I was working on getaway also. Let me know if you want to pool our resources. I tried to PM you but pinside didn't cooperate.
Quoted from jamescardona:
I've actually already created 7 different versions for The Getaway. All available here for download: http://pinsound-community.org/forum/index.php?/files/category/22-getaway
You are welcome to "borrow" anything from what I've done for your own custom orchestration. Just commit to posting it to the community site and share with others. What kind of theme do you have in mind?
Guys I cant iron down that horrible humming that is common in most Data East pins, if I get the Pinsound, new speakers and new wires I wonder if this would solve my Jurassic park issues I'm having.
Quoted from JediPimp:
I'd love to check it out!
Quoted from Marcdaddy:
Can't speak first hand, but I have a friend that has a DE JP and previously had all kinds of noise. He did different things to insulate his boards and I know he put a secondary power source in to drive PinSound and some other stuff. I bet if you search through and of the DE threads (Jurassic Park is what comes to mind) you may find some answers.
Quoted from jboner1058:
Any news about data East system 2 games like Simpsons and Phantom?
Or BTTF
I've put Pinsound in a Last Action Hero and a Jurassic Park. Neither one had any hum or slight buzz that the originals sound boards had. The LAH was cutting out at high volume so I put in a switching power supply to power it. Jurassic Park was okay. The difference with LAH is probably due to the fact that it still has the original power supply board and the best sound mix for it is mostly heavy metal music (more bass) causing more power draw. The JP has a newer Rottendog power supply.
Oh, and the mix for JP by Endprodukt is superb.
Just did the same for both of those machines as well, and both mixes are huge upgrades to the games. I also had to add a power supply to LAH (I used one those DC-DC converters from Amazon to go from 18V to 12V) but JP was fine. In case anyone runs into this, I needed to turn the volume pot all the way up on JP and use the volume adjustments on the board, otherwise it just made loud obnoxious sounds in attract mode.
This was alluded to earlier in the thread, but I wanted to confirm: If you turn up the volume on the Pinsound board (Especially if using the stereo cable), the board seems to draw more power. If you're having power issues, it may be worthwhile to turn down the pin sound board volume, and turn UP the game via the coin door buttons. I usually set my games to 8 or 9, and I've had it all the way up to 18 or 20. on WPC games, this keeps the PInsound board from drawing too much power, and may be a way to avoid adding a power supply. I'm not sure about DE games but it may be worth a try
If anybody is looking to take a dent out of the price of a Pinsound, I am looking for an original wpc-89 sound board working. Please pm me.
Has any one ordered a Pinsound kit directly from France lately? How long has it been taking to ship to the United States? I am worried my shipment is stuck in customs, because my tracking has not updated since January 4th.
Quoted from jzdziarski:
No, but K's Arcade carries them domestically.
Unfortunately, they don't carry the Stern Whitestar kits. This is why I ordered directly from Pinsound.
