I am having an issue with the pinscore display on my Earthshaker. Display has been in the machine since I purchased it in January with no issues. It is showing numbers in places they should not be at the time. When you start the game there should only be the two 0's there, and also some digits are brighter than others they are in the same position that the digit is in that isn't supposed to be there. I attached 2 photos. Is the display going bad? What should I check? Any suggestions would be appreciated.
