Have one confirmed display from a 6 digit set and another from a 7 digit set that is giving me some flicker and segment issues.
Tested the 2N7000 segment drive transistor and seems like it is the culprit but may also be the decoder because of the flickering.
Had tested on the bench top with a 5 volt power supply per the directions to give a number “8” in each digit.
Can I modify the wiring to the display to get other numbers 1-9 by changing which pin has ground or voltage on pins 16-19 of the BCD D0 thru D3?
I made a wire harness when I built these per the table below. Thx
