Finished up installing the Pinduino Interactive LED kit on my Lord of the Rings.
Addressable LED strips are installed on the apron, backboard and along the inside of the cabinet. The strips on the cabinet are attached to aluminum angle that's held on with Velcro. Using Velcro allows the aluminum angle to be removed if the playfield needs to be raised.
With the Pinduino you can easily customize the programmable LEDs to change color, flash or fade based on J6 or J7 triggers. The possibilities with the Pinduino are endless.
I want to give a huge shout-out to Eric (@lyonsden) for his help in setting this up.
Here's a video of the LEDs in action:
