(Topic ID: 212424)
Pincraft - A Homebrew Pinball Story (Kings of Steel Conversion by Myth Pinball)
By MythMaker
6 years ago
  • 301 posts
  • 32 Pinsiders participating
  • Latest reply 12 days ago by MythMaker
  • Topic is favorited by 47 Pinsiders
There are 301 posts in this topic. You are on page 3 of 7.
#101 5 years ago
Connor helping to organize wires. We are organizing them by length and laying them out on the ground.
#102 5 years ago
Warning... if you don't want to experience the pain of wiring.. you may want to skip lots of posts past this point!
#103 5 years ago
Starting the first wiring loom on the playfield. This will be the flipper loom (later we learned putting all the flippers on one loom was too much power draw... recommend to everyone put one flipper on one side of a PD-16)
#104 5 years ago
Here is the first loom almost completely wired up.
#105 5 years ago
And here is the connector that will go to the head of the game. We made connectors here to make it easier to remove the playfield going forward.
#106 5 years ago
And here it the playfield back in the game...
#107 5 years ago
Here is the connector from the playfield to the head.
#108 5 years ago
Very excited to try to get everything flipping, so working on downloading and setting up MPF.
However it doesn't even matter, as just powering up the game is causing all the coils to lock on. Here we are trying to debug why this is happening...
#109 5 years ago
While getting very frustrated we worked on mapping out where the next wiring looms would be going, assigning coils to each colored loom.
#110 5 years ago
We tried using the old power supply from the original Kings of Steel. My other Bally game broke so we decided to use that power supply board over there.
So the question came into, should I spend the money to buy a new power supply board or replace the power supplies with solid state supplies.
Since we were still having power issues, we decided to swap the power supplies completely out.
#111 5 years ago
Here are the new power supplies being wired in. A 12v and 5v power supply and a 48v power supply.
#112 5 years ago
We also added a cap board for the coils (same as used in TNA from Spooky)
#113 5 years ago
And here is the full wired setup.
#114 5 years ago
SUCCESS! We have power to the boards... Seem happy for now...
#115 5 years ago
The flippers still were locking on. The ultimately problem is we didn't have the 12,5, and 48v on a common ground. Without the common ground all coils were locked on.
We ran an extra ground line from the 48v supply to the - line on the 12 and 5v supplies and this fixed the issue.
Here is an article on this if anyone else runs into the same issue:
http://docs.missionpinball.org/en/latest/hardware/voltages_and_power/voltages_and_power.html#common-ground
#116 5 years ago
The last issue we ran into is that we could only get the hold coils to work on the flippers. The solution was the cut the diodes and wire the flippers backwards. This solved the issue.
#117 5 years ago
great to see you are back, and right into it
#118 5 years ago
Awesome thread. Thanks for sharing all this.
#119 5 years ago
Great work. I, for one, enjoy seeing the wiring posts and pics.
Dave
#120 5 years ago
Quoted from MythMaker:
Unfortunately this is a common problem along new users. We took this as an opportunity to add warnings to all coil related pages in the docs (i.e. http://docs.missionpinball.org/en/dev/hardware/multimorphic/drivers.html).
Jan
#121 5 years ago
Following. Looks great
#122 5 years ago
We were having some problems getting MPF to work, so in the meantime we started planning out the next wiring looms.
With 2 PD-16s we get 4 banks of 8 outputs. Each flipper takes 2 outputs, and we have technically four in the game (two lower, one upper and one gate diverter)
It was important we plan out our wiring looms to make sure we account for every coil. We also have a drop target bank with individual reset coils that takes almost a whole loom by itself (1 for reset, 6 coils for drop target down)
#123 5 years ago
After having an impossible time trying to install MPF on an older computer, my F*'it brain said lets just pick up a new computer to load this thing on.
Here is the current setup, using a mini-pc wired up to the head.
The nice part about this PC is technically it is small enough that we could re-load it with linux and put it in the cabinet when we are done developing as well.
Hard to see in the pic, but that black box by the monitor is the new PC.
#124 5 years ago
And success! Finally we had MPF up and running and got the game flipping!
Now while most of you would post a first flips video after you got the bugs out, I figured I would post our REAL first flips video:
https://vimeo.com/327365853
Notice without using EOS switches, the default power to the flippers is not enough to get a full flip. Later on we adjusted the flipper power and got them to work correctly.
#125 5 years ago
This was a lot of work to get to this milestone, but the sense of achievement says all.
#126 5 years ago
Awesome work! Keep it up!
#127 5 years ago
We need more room on the playfield to mount the SW-16 boards and PD-LED boards that will be used in the game.
So we built some riser boards out of some left over plywood and some angle brackets
#128 5 years ago
And here is the risers with a SW-16 on the left and a PD-LED board on the right. On the backside will be another SW-16 and PD-LED board.
#129 5 years ago
Then we begin wiring up the next harness..
This one will include the pop bumpers..
#130 5 years ago
And the ball trough...
Lots of wiring
#131 5 years ago
So now we have the green and the blue harnesses done on the game (2 out of 4 looms).
Here is the picture of the wiring progress so far...
#132 5 years ago
And the game flips!
Although at this point it isn't too exciting, since we have NO switches wired up. That means only the flippers really work.
#133 5 years ago
Next thing to tackle was the drop target bank wiring. I wanted to try to re-use the old connector so it was easy enough to remove the drop target mech in the future.
This semi-worked. I was able to use the connector for the solenoids and one bank of switches, however had to put the second bank of switches on its own sw-16 header.
This is the connector that runs to the PD-16 bank and one of the SW-16 headers.
I ended up using pretty much an entire SW-16 dedicated to this drop target mech. There are 6 switches for the drop targets and 5 switches for the targets behind the drop targets.
#134 5 years ago
Time to build the last of the playfield looms.
Here you can see the box of wiring we used to pull a loom through..
And here is Connor showing off the 4 completed looms. The last loom only required 3 coils at the moment.
#135 5 years ago
And here is all the coil wiring in place on the game...
#136 5 years ago
The next step is to get the switches working... This part is really exciting, because after the switches are working the game really comes to life!
First step is to run power to all of our boards (SW-16, PD-LED, and Optos).
Here is an opto power board that we used from Pinball Life, we have two of these in the game. One to power our trough and scoop optos and one to power our upper gate optos.
#137 5 years ago
We also powered up one PD-LED board and here is a picture of our overall layout with lights for the first time!
#138 5 years ago
Now it is time to get ALL the switches wired up. This is a very time consuming process for sure.
I also removed all the diodes from the equation as they are not needed for SW-16 boards.
Here you can see one of our SW-16 headers. The wires here are much thinner 22-gauge wires.
And here is an overview of some of the switch wiring. You can see the trough wiring and shooter lane switch that we put in.
#139 5 years ago
A most important member of the team helping out of course...
#140 5 years ago
Having trough switches means we can actually start programming in our game..
Here is our first set of switches programmed inside of MPF
#141 5 years ago
And here is our very first score display...
And first actual game with 3 balls and the ball trough working...
#142 5 years ago
Had to make the display look a bit better than it did and actually show the score, so setup a slide_player in MPF and grabbed a few custom fonts..
Looking better...
#143 5 years ago
Game is pretty fun, but boring without pop bumpers! Time to add some more switch wiring...
And now here is the fully populated SW-16 board...
#144 5 years ago
And here is all the game wiring to date...
#145 5 years ago
Playing catch-up here on the posts! So forgive the number of updates on one given day!
#146 5 years ago
Next it was time to tackle the drop target assembly itself. Unfortunately all the switches needed to be re-wired because the theory of operation was different.
Originally it was column and row wiring, which meant they used the same wiring for the rows and just strobes different grounds (columns). Since now we are using dedicated switches, each of them needed to be re-wired.
#147 5 years ago
Even after having two riser boards, we needed more room to mount more switches.
So here is another section of riser boards, one will be for more switches, the other for another PD-LED board.
Was careful to mount these so it would clear the playfield rails.
#148 5 years ago
Next we had to build the power harness for the PD-LED and SW-16 boards. Annoyingly enough they use different voltages. The 12v for the SW-16 boards and 5V for the PD-LED boards.
#149 5 years ago
Also had to run power to this upper opto power board that will be used for the loop optos (eventually).
#150 5 years ago
We needed to add loop optos so we could open and close the top gates and award loop shots. Otherwise we had no way to detect a ball going around the loop.
We choose optos because the lanes were a bit wider than a standard switch would accommodate. Plus we had the drop target mech in the way as well.
Here is the left loop opto being installed..
And here is a view from behind the rail...
These are tricky to get working right, and of course one of the wires was backwards by accident, so that had to be adjusted as well.
$ 18.00
$ 115.00
$ 85.00
This page was printed from https://pinside.com/pinball/forum/topic/pincraft-a-homebrew-pinball-story/page/3 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
