Hi everyone,
I picked up a Pinbot last month as my first pin and everything was working great until last week (after disassembling, cleaning and waxing the playfield) at some point the solenoid that raises the ramp stopped working. I didn't even realize it until the startup diagnostic told me a few days ago that switches for ramp down and the energy target hadn't been triggered. I manually triggered the switches and they worked fine, and after going through the solenoid tests the one that lowers the ramp is working but the one that raises it (I think it's solenoid 5a in the manual) does not.
Being a complete noob at this I'm not sure what to do next. I've looked at the wiring and having noticed anything out of the ordinary around the solenoid, I've pushed in on all the connectors in the backbox in case something had come loose. I got a cheap multimeter and tried figuring out how to use it. It seems like there's power going to the solenoid, but I'm not 100% positive since I have no confidence in my skill at using the DMM.
Is it likely that the solenoid just needs replaced? Or is it more likely that there's some other issue? Every other issues I've seen on the forums regarding solenoid problems usually have something to do with capacitors or fuses or something, but they're also usually bigger problems like multiple solenoids acting up.
Thanks for any helpful advice!
