I have an issue where the visor is acting up. The game will play normally if I don’t have the ramp down switch activated. When I do the visor goes up and down and nothing works correctly. In switch test all switches work normally as long as the visor switches aren’t closed. If one or the other is closed, all switch tests in that column register as either of those two switches depending on which one is closed at the time. I’ve tested all the switches and all of the diodes. I’m thinking it must be on the board. Am I missing anything? Also when the game first starts the ramp flutters up and down a few times. I’ve seen others have broken off wires causing this but I’ve extensively checked all diodes and connections
