I searched the forum and didn’t see a thread which matches my problem.
The Problem: The upper lights on my Pinbot are non functional, verified by a lamp test. (See photo of game in attract mode). The center 5 lights in the middle and the two bulbs above them DO WORK.
All fuses have been verified good via a multimeter.
I’m reading the schematics to try and isolate the problem but thought I would throw it out to the group first.
NOT SURE IF THIS IS RELATED: But prior to noticing the problem I began replacing the incandescent bulbs in the backboard with LEDs ( no lamp board modifications have been done. ) after replacing 15 bulbs I powered the machine up and got a noticeable humming noise. Shut unit off, then on and hum is gone. Can’t say for sure if the upper lamps were functioning before my LED upgrade. I have since removed all the LEDs andput the original incandescent bulbs back in, but the upper 1/2 of the backboard is still out.
It is important to note that beside the lamp problem the game is top notch. Plays well, all music and electronics working well.
Thanks for listening.
