(Topic ID: 125074)
Pinbot - Up/Down Advance Switch, tilt, vortex
By Tanooki
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by RCA1
#1 4 years ago
I got a home only use Pinbot yesterday afternoon and have been going over cleaning a couple decades of funk off the interior of the playfield.
There's 3 things I need to address.
1) The Up/Down Advance Switch on the inside of the coin door someone ripped some wires off of it, so I can't go through any procedures. How is this exactly wired up? I took a picture of what I'm looking at currently.
2) Next to that, seems the tilt has been disabled. Does this look properly wired and all I need is a bobber on that pole and a ball in the track there to re-enable that?
3) No picture -- Vortex. I can't get it much beyond 5000. Farthest was on the back side of that half up to 100K. I've de-gunked and polished the vortex, the playfield, and the ball ramp from the plunger with no improvement. I tried the moving around of the plunger itself with no benefit, do see the rubber tip is shot, little left on it. It doesn't appear to be warped but clearly people (not too much unlike me) who have little to no knowledge let this go or messed with it maybe?
One last thing, on boot it says Adjust Switch 22. I'm trying to thumb the manual on a PDF here, I think if I'm understanding this Pinbot is smart to X plays it has, after X plays it wants a reset (3000 default) is this correct? Clearly I could stop this if one of the two previous owners hadn't pulled some wires I imagine on accident.
#2 4 years ago
Hopefully this can provide a bit of assistance:
1. Attached pic of how mine is wired, don't have the manual on me right now to confirm what colored wires hook up where.
2. Looks correct, only need your plumb bob and roll ball to fully enable that functionality
3. Double check what color plunger spring it has, ideally it should be blue, red for a even more power.
4. Yeah, it has a setting to reset certain settings after so many plays, High scores, auto percentages, etc... To fully reset the settings, with the machine off, pull one of the AA batteries off the CPU board in the back box for a couple seconds, should force a factory reset of all settings.
#3 4 years ago
What Pepse said.
Additionally, there is a sleeve in the shooter housing similar to a coil sleeve. That may be worn or gummed up. Try to clean/replace that and you may get some improvement. Also, polish the shooter rod with metal polish while you have it out of the sleeve. If the rod looks rough (or worse, rusted) replace it.
2,250 (OBO)
Marietta, GA
5,800 (OBO)
Waxahachie, TX
$ 99.00
Pinball Sales
$ 14.50
PinballElectronics.com
$ 44.95
PinBoss Mods
$ 17.00
$ 175.00
Professor Pinball
