Quoted from Croppie1Kenobi:Found this relay today and this doesn’t seem right? Can’t seem to find the schematics for those boards. Should be to ground or 28v?
This is a AC relay. It is wired correctly. This board was used for different uses so the labeling isn't correct when used as a AC relay. The Gnd terminal is really the relay common terminal. 28 volts is connected to the Com terminal, the brown coil power ( A side) wire is connected the the Normally Closed relay terminal. The orange (C side) wire is connected the Normally open relay terminal and powers the flashers. If the relay stops working the solenoid coils will continue to work but not the flashers.
Quoted from GRUMPY:This is a AC relay. It is wired correctly. This board was used for different uses so the labeling isn't correct when used as a AC relay. The Gnd terminal is really the relay common terminal. 28 volts is connected to the Com terminal, the brown coil power ( A side) wire is connected the the Normally Closed relay terminal. The orange (C side) wire is connected the Normally open relay terminal and powers the flashers. If the relay stops working the solenoid coils will continue to work but not the flashers.
Thank you
This page was printed from https://pinside.com/pinball/forum/topic/pinbot-under-playfield-relay and we tried optimising it for printing. Some page elements may have been deliberately hidden.
