Hello Folks!
(X-posted from the Pinbot Club)
I’ve recently picked up my first machine (Pinbot!) and I’ve been trying to track down a why the top Playfield flashers are not working. Bulbs are good and replaced, sockets are good. Resistor boards all appear to be fine.
These lights are on the same switch as the ball trough feeder which works fine. However when I looked at the relay at the back right of the playfield that seems to run the feeder the solder job looks a bit brutal (top relay in picture, the one closer to the front of the playfield).
None of the other relay boards have a COIL connection, and it seems surprising to have GND and +28 connected! Perhaps this was a fix to route around a bad relay board? However I do hear the click when running the flasher test.
Might have to replace this. Could someone please snap a pic of what this should actually look like?
