Hello again Pinsiders!
I'm now here trying to solve a problem with the target bank of my Pinbot which sometimes hangs and wont go fully down (or fully up). When this happens, if I took the glass off, put a finger over the bank's plastic and I can feel the vibrations of the motor that is still running. Eventually the machine will give up, and the game continues with the bank in any position. On the next action that should open (or close) the target bank, it does get in the correct position.
Today I got the courage to disassembly all the visor. Started with the helmet, then the ramp (with the two connectors under the playfield), then the visor, and also i took the opportunity to remove the plastic that's behind the visor (part of pinbot's face) for cleaning. Then I went under the playfield and removed the 4 screws that attach the motor assembly just to found that the "metal part" of the motor and the plastic part where that metal part goes in order to move the target bank was full of grease, and also found that along a lot of shitty repairs, the "Open visor switch" (white/vio cable on the switch matrix) has a diode and one of its pins was broken (probably because of the movement I did when i took it away).
I will have to clean all that grease over the moving parts and I will have to replace that diode, which it is a 1N4001 diode. Is there something else I've to check, now that i've the motor disassembled?
This is the diode:
The grease all over the place:
